Thread: Ready for Salt ?? Test Results
    Apr 2009
    New York, Texas
    26
    Test results are as follows:
    FC - .5
    CC - .5
    TC - 1.0
    pH - 7.5
    TA - 100
    CH - 50
    CYA - 40
    Am I ready to put salt in the pool? I have 800# sitting on the coping and another 200# in reserve.
    Thanks ...
    Jack
    40K gal rectangular IG Gunite ... white plaster ... 20 ft negative edge ... 2 Intelliflo VF 3050 pumps ... 2 Sta-Rite Cartridge filters ... IC60 SWG ... Pentair Thermaflo heat pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Ready for Salt ?? Test Results
    Your ready to add salt as it will not affect any of your numbers, but before you just dump it in you may want to test your current salt level as you will likely not be starting at zero.
    to add... if you will be using a SWG you may want to lower TA to 70-80 and increase your CH level, since you have a gunite pool.
    Quote Originally Posted by dmanb2b
    Oh yeah, test beforehand. I purchased salt and a salt test kit yesterday, assuming my starting salt level would be rather low. Turns out it was 1400ppm!
    17,000 Gallon plaster pool. Hayward Perflex EC65 DE Filter. 3/4 HP Hayward Superpump converted to dual speed. CircuPool RJ45. Skimmer, floor drain, two returns.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    um...just read you sig...
    Let's see that pool welcome to TFP...given the neg edge you will likely experience frequent PH rise...keeping TA at even 60-70 will help tackle that issue.
    Mar 2010
    Spring, TX
    1,082
    I also think for a CYA of 40 your FC is very low. I am sure others will be along to expand.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by mynewpool
    great catch Raise your fc to at least 3-4ppm for now....if you are aiming to use your SWG, you'll want your CYA at around 70ppm.
