Thread: Is the Hayward TriStar a variable speed Pump?...
    Jul 2010
    North Bergen, NJ
    172
    Perhaps I am really confused as to what constitutes a variable speed pump, but if The Hayward TriStar Pump is a variable speed pump then why are there versions of it on website price lists that list 2 Speeds and Single Speeds?
    The literature mentions there are 6 programmable speeds on the Tri Star...so can someone clarify what this all means?
    I am trying to purchase a pump that is powerful at 1.5 HP for backwashing and adding upgrades later on like (a spa or waterfalls, etc) so I only want to use a 3/4 HP speed right now for most of my pooling (14x28) but want to have the power when I need it.
    Also, why is the TriStar's most expensive model only about $650 when the Pentair's most expensive VS VF model over $1200??.....What is the Pentair giving me for that extra money??
    thanks for helping me clarify
    Design 14x26 (10,000 gal) in ground vinyl pool, 2 Wide Mouth Skimmers, 3 Returns
    Equip 3.0 HP Pentair VS pump motor, 48 FNS Plus DE filter, IC20 SWCG, 400Btu NG Heater
    Extras Easy Touch Automation, Pentair LED Lite, Kreepy Krawl Racer pressure cleaner
    Water pH 7.5, Total Alk 90, Free Cl 4.5, Combine Cl 0.25, CYA 65, CH 275, Salt 4100ppm, Borates (Boric Acid) 50ppm
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Is the Hayward TriStar a variable speed Pump?...
    The TriStar comes in single and two-speed models, as well as the TriStar Energy Solution Variable Speed model. The Energy Solution is often priced without the controller, which sells for around $400.
    To say what John said another way, the Hyward TriStar is a single/dual speed pump. The Hayward TriStar Energy Solution is a variable speed pump. They both use the same wet end, but the Hayward TriStar Energy Solution also has an electronics box that provides the variable speed control. The electronics box comes in two versions, one designed to hook up to a Hayward automation system and the other designed to be used either standalone or with some other brand of automation system.
    Hayward is in the process of discontinuing the TriStar Energy Solution, and replacing it with the EcoStar, but that won't really happen until the spring.
