Results 1 to 19 of 19
Thread: Pool wall insulation
    Hi Everyone,
    I'm a longtime lurker but this is my first post on TFP so go easy on me .
    I'm planning to put in a DIY vinyl liner inground pool next spring. I'm still in the planning stages and am very concerned about heating costs(I'm in NH). I was wondering if anyone has insulated the outside walls of their pool with spray closed cell polyurethane insulation. If you install a pool with polymer walls would this have an adverse effect on them? Would the insulation hold-up to the elements and during the backfill?
    I understand that most of the heat loss comes from evaporation. I'm just wondering whether it would be worth the effort to try and insulate the walls. I do plan on applying 1/8" foam to the inside of the walls.
    Thanks in advance for all the responses,
    Jeff
    15' x 30' Rectangular, 6 ' deep end; 30 year old in-ground - ~15,000 gal.; Gunite/plaster pool surface; Screened in "Florida Room"/cage over the entire pool; Cool Deck patio surface; 3/4 hp Magnetek Pump motor; 1-1/2" PVC plumbing w/ 2 returns; Pentair Clean & Clear 150 sf cartridge filter; Baker Hydro Skimmer & separate dedicated vacuum port; Sta-rite Great White cleaner; TF100 Test Kit. & BBB chemicals
    Dec 2009
    Central Massachusetts
    2,690
    Re: Pool wall insulation
    Wouldnt do much if anything at all, really. The outside of the walls are "insulated" with backfill. A little foam on the outside wouldnt contribute to stopping heat loss. The vast majority, if not all heat loss comes from evaporation.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jul 2010
    Oklahoma City
    71
    Go check out http://www.insulatedpoolkits.comThey sell kits using insulated foam panels for the walls, and seem to have some data to support the theory that more heat is lost through the walls than through the surface.
    Dec 2009
    2,690
    Lets just say I do not believe their claims of 15-20 degree increases water temperature.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    If you really wanted to insulate the walls, you could just get a normal kit and have someone spray-foam the walls separately, for less money than they want for it.
    I agree w/ bk406; you're not going to get 15-20 degrees difference. I would be surprised if you got any. Dirt is a pretty darned good insulator by itself.
    mas985's Avatar
    Pleasanton, CA
    11,741
    I would trust the Florida Solar Energy Center from the University of Central Florida over any other source since they are one of the leading research institutes in solar energy. According to this document, Figure 1 shows that conduction through the walls is minimal and probably less than 5% of the total heat loss.
    Of course if you use a cover and eliminate evaporation, then convective and radiative become the dominate heat loss mechanisms but conductive is still pretty small.
    Mark
    Henry Porter's Avatar
    Nov 2008
    Sweden
    604
    I have insulated my walls and I think it's worth while atleast if you have a pool that needs to stayed covered most of the time.
    The topsurface of the ground is constantly chilled down from wind/rain and dropping night temps and insulation prevent that enviromental impact from chilling down the top surface of your pool walls, so if there should be any insolation it's probabaly from the top and a couple of feet down, Further down my guess is that it becomes less and less important.
    I loose around 1- 1,5 C during a night with my solar cover on and that is with a water temp of 86 and with a night temp that drops down to 57. And from what I have read from other swedish pool owners in my area that's pretty good.
    If that can motivate the extra cost it takes to make an isolated pool! I don't know but it feels good now when it's done. For us that used celluar plastic was the cost not so significant if you consider the total cost of the pool.
    EDIT: a couple of feet down from the surface is where I think insulation makes most impact and not a couple of inches that wrote.
    Inground concrete pool 14600 gallons,Pentair Whisperflo 3/4HP WFE-3, Hayward swimclear 420sq ft
    Zodiac LM3-24 SWG, Dolphin Diagnostic poolrobot, Heatpump Gullberg&Jansson 13,8KW, TF testkit.
    Seen a shooting star tonight And I thought of you You were trying to break into another world A world I never knew
    I always kind of wondered If you ever made it through Seen a shooting star tonight And I thought of you
    Jul 2009
    London and France
    574
    I think someone missed out the decimal point! 1.5-2.0 degrees more likely.
    Some helpful info:
    http://www.poolinsulation.com/
    A report commisioned by the above but carried out by a respected body the Building Research Establishment, all new pools in the UK must be insulated as part of our buiding regulations.
    http://www.poolinsulation.com/img/brereport.pdf
    The polystyrene and reinforced concrete block pools are very popular as you get insulation and considerable build strength in a very realistic price.
    If that is not available, consider using insulated concrete forms (ICF) which are used for basement foundation construction and also whole buildings now, google it should bring you plenty of info.
    mas985's Avatar
    Pleasanton, CA
    11,741
    While interesting, keep in mind that the BRE report was commissioned by several commercial companies with interest in convincing consumers to insulate their pools so it is hardly independent research. But it doesn't invalidate it either.
    Second, the report only really focuses on the insulation and heat loss through the walls and total ignore the other mechanisms of heat loss. You really have to put heat loss into context by comparing it to the total heat loss of the pool. No one is arguing that there isn't heat loss through the walls. Only that it is minor compared to the heat loss through the other mechanisms in most residential pools.
    However, if a hard highly insulated cover is used which minimizes evaporative, radiative and convective heat losses, then and only then does conductive heat loss become dominant. But I would still argue, it is small. I would only consider insullating the walls if you were heating the pool with gas or electric and you had a highly insulated cover. Otherwise, it is simply not worth it.
    Mark
    Jul 2009
    London and France
    574
    Agreed Mas985,
    I cannot find any reason with the type of pool I described not to build though. cost good, strength better than plastic or steel panels, insulation a bonus!
    Wow, lots of real good information. My plan was to buy one of the Tiger foam insulation kits and spray the outside walls myself. For an inch of closed cell foam I believe you would get R-7 and a kit would only run around $600. I'm still not sure it's worth the effort or not. It seems like it would be inexpensive and fairly easy to do.
    I am also new to the site but I tend to agree. I have a bi level home and half my lower level is 4' underground. When I remodeled I spray foamed the entire walls. From the cinder block up to the stick framed OSB walls. Then I went back and put fiberglass batt over that. R-20. No air movement.
    I also used Tiger Foam. Why not spray the outside of pool walls, and especially the suction and return lines. Whats $600 on a $30,000 pool. I know the difference on a cinder block wall was great. The difference between touching a below grade wall without foam and with foam was night and day.
    Dirt is 55 degrees. There has to be heat loss into it.
    Dec 2009
    2,690
    The BTU required to heat a house for a entire winter is dwarfed by comparison for what it takes to heat even a relatively modest 20,000 gallon pool. Any kind of insulation on a pool other than a solar cover would do minimal, if nothing at all, to prevent heat loss. 99.9% of the heat loss from a pool is from the surface, not the walls. Save the $600 for something more useful
    Feb 2011
    Sicklerville, NJ
    80
    This is an interesting topic. Anyone who has been camping knows the difference a 1/2" foam pad makes when used between the sleeping bag and ground on even a mild night. For someone who spends thousands every season on heating, even a few percent savings on that would add up over several seasons. It may pale in comparison to an insulating cover but it's also a one-time installation then forget it deal.
    The problem I see is, the walls are only half (or less) of the ground-to-water conduction area. What about the floor? Would the pool be more prone to freezing in colder climates as well? Interesting to think about anyway.
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    Try this analogy, what difference does it make if the wall is insulated or not when the window is left wide open all the time? Yes, technically there is a difference when you insulate the walls, but it isn't something you would normally be able to notice. If you are planning to put three or four inches of foam on top of the pool when you aren't swimming, the way some people do with a spa, then it is time to talk about insulating the floor.
    Feb 2011
    Sicklerville, NJ
    80
    Even though we're leaving that window wide open, we're still turning the heater on to warm the room. If we can use insulation to replace pumping in more heat energy, even to a small degree, is there a cost benefit over decades of pool use? With the way energy prices are going I wonder if the answer is that simple.
    Yes, it will save some energy, and it doesn't hurt anything. So sure go ahead. I just think that there are better ways to spend that money, but that is a personal choice rather than an absolute statement.
    Sarnia, Ontario Canada
    162
    I am considering insulating the walls and floor of my pool with fiberglass door cut out panels. These are what are cut out for windows. Less than 2" thick r-12. A tigerfoam kit to fill gaps The ground temperature around here is about 50 deg.
    I think this will help the swimming season start earlier and go longer. But one must keep the pool covered when not in use as evaporation will remain the largest heat loss... If you won't consider covering with a solar cover, you are likely wasting your time and $$.
    20x47' double roman vinyl liner pool. Pentair EasyTouch 8PSC-IC40, 011018 Pentair IntelliFlo, Pentair Clean & Clear Plus Filter CCP420, Pentair 120V IntelliBrite LED, Cleardeck indeck solar reel, 530 sq' solar system Polaris 9300xi robot, Interfab Turbotwister slide, S.R. Smith T7 diving board, deck jets vinyl-liner-pool-build-in-ontario-canada-new-pictures-t30213.html
    Feb 2011
    Sicklerville, NJ
    80
    There is a great deal of information out there if you look for it. It seems to be very popular now with building things "green" and all.
    What I learned boils down to this: yes, soil has a poor R-value but that doesn't automatically mean insulation will make a big difference. Despite being a poor insulator compared to other materials, the massive amount of soil under your pool makes having a few inches of insulation seem like nothing in comparison. The determining factor is moisture content. If the soil is completely dry, adding insulation does no more good than having a few extra feet of dirt under the pool. If the soil is very wet, though, that water can move heat away very quickly.
    So if we want to insulate a pool, we should build an outer waterproof shell, line that with thick insulation, then top it with the pool liner, making a giant Thermos. And make sure to cover it well... otherwise don't bother at all
