Results 1 to 12 of 12
Thread: Looking for pool shape ideas
    Hi, first post to this forum...been reading a while to get some ideas. My backyard is narrow at one end and opens up at the other. Narrow end, keeping in mind concrete and space to the fence and deck, will allow me to get 12 feet of pool in width (for about 15 feet of length) and then I can expand to 16 feet width (for about 20 feet). My plan is to utilize the narrow end for shallow and then as it widens, drop to deep. The shape will be a humback kidney.
    I will post pictures of the yard later today. Does anyone have suggestions or pictures of similar pool setups?
    Thanks
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Looking for pool shape ideas
    Welcome to TFP.
    I'd recommend you take the time to understand the effect pool shape has on the use of a solar blanket. I realize you may not be able to choose a shape that is good for a solar blanket reel, but sometimes minor changes can make a big difference in how convenient it is to use.
    Anywhere you can point me to some information on this? I intend to use a solar blanket, so do need to keep this in mind
    Thanks
    Dec 2009
    Central Massachusetts
    2,690
    Johnt makes a good point. But, IMO, dont decide on a pool shape just based on that. I have a kidney, a solar blanket, and a reel. It work just fine. Maybe some of the free forms might be an issue, but a humpback kidney isnt an issue.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    where do you have a roller typicallyin a humback kidney? Is it at the wider end or the narrower end, or lengthwise?
    Dec 2009
    2,690
    On a kidney, you put the roller on the wider end, and put the roller over the pool instead of on the end. You actually have about 4-5 feet of pool and cover behind the roller.
    If over the pool, how is the 4-5 feet covered? Do you essentially have 2 solar blankets?
    SW Indiana
    9,199
    Quote Originally Posted by Styx555
    No, you anchor your straps on the cover directly under the reel and it rolls it up from both directions. Sometimes you have to unfold the short end by hand when putting the cover on the pool.
    Dec 2009
    2,690
    Quote Originally Posted by JohnT
    Yep, what JohnT said. If I think of it, i'll snap a pict of how I have mine and post it.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Styx, how about a picture of the area in question?
    will post tonight when I get home
    A few pics to help out. The pool will be 36 feet long, 13 feet wide at shallow end and 17 feet wide at deep end
