Thread: Pumps, pumps, pumps... design questions
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Hi all,
    I am in the design phase of an owner-contractor build.
    I am building a 20X30 IG gunite pool with an included (in that dimension) spa 9X9. I will also have 3 deck jets.
    My questions are regarding pumps.
    Between the spa and tanning shelf and steps, the actual deepwater pool will be 20X20, so I figured a 3/4 hp pump will be fine for circulation/filtration.
    However, since I have the spa, I am going to include a larger separate pump to handle the spa jetting and such. Do I want to just use a booster pump to handle the jets or do I want to go with a variable speed pump like the VS or VF. Cost is not so much an issue, I just want to get it right. I have thoughts like "well we are not going to have the deck jets on unless we are in the pool or entertaining, so I dont want to pay to run a larger pump all that time...."
    Recommendations? Whats your idea of the "smart" way to do it?
    I will have automation to handle valving and pump on/off if that impacts decisions.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Pumps, pumps, pumps... design questions
    Oh, clarification I just re-read my post.
    Do I want to use a booster pump to handle the DECK jets.
    I plan to have a separate pump to handle the spa, with drain and returns/jets in the spa so its like a separate spa (though I will have a "pool return" in the spa to keep overall circulation of water happening.
    Guest
    Circulation pump (for pool or spa, variable speed), jet booster pump for jets and water feature pump for deck jets. This configuration allows you to use anything you want at any given time.
    Congrats for thinking it through and doing it right
    It is really nice to have a variable speed pump for the spa jets. That lets you dial in exactly the amount of jet action you want. The electrical savings are minimal, since you have to run on a fairly high speed in spa mode, and most of the electrical savings come from running at a lower speed, but the adjustable jet strength feature is very cool.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    So... How about a 3/4 Hp (2 sp?) for general circulation, a vs for spa, and a booster for jets? Couple that with some actuated valves that open when the booster comes on for the deck jets?
    Edit.
    And maybe an actuated valve turning off the pool circulation return in the spa when the spa pump comes on to minimize cold water from pool flowing into heated spa? Boy this gets complicated quick....
    How to valve the heater so I can choose to heat spa only or both pool and spa... Hmmm.
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Quote Originally Posted by Lershac
    Edit.
    The VS would only operate the jets; the circulation pump would be the one to send the water through the heater. The output line from the heater would then go to an actuated valve which would send the water to the pool, spa, or both.
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
