Results 1 to 10 of 10
Thread: Need a Skimmer for pool with a sweeper. only one return.
    Aug 2010
    San Diego
    18
    I have been reading and researching all day to try to figure out a solution to my problem of no skimming.
    I have one return skimmer. I bought a poolvergnuegen sweeper that is AWESOME. works great! BUT now I don't have a skimmer. The combination of the trees around my pool and my dogs in it I end up with a LOT of floating debris. So everyday I am skimming the pool with the net.
    I saw the pentair vac mate at the pool store and thought that was the ticket but have read that most people don't like the vac-mate.
    Also the Polaris LCS Leaf Canister & Skimmer looked great but it is expensive and discontinued. (I have found a few sites that still have them in stock)
    Some people like the pool devil or pool skim and that might work but I only have two returns in my pool and as it is right now i have to valve most of my return to the spill over jacuzzi so i don't push the hose for the sweeper in to the deep end causing the sweeper to stay in the deep end. Also the returns are not threaded. there is one return that is threaded but for some reason it was plugged some time before I got the house in October. It is plugged with some sort of rubberized putty or caulking.
    Any Ideas...
    27,000 gal 615sq/ft surface area jacuzzi attached
    FNS Plus pentair 48sq/ft DE
    In ground plaster
    Intelliflo vs, EasyTouch and Intellichlor
    Guest
    Re: Need a Skimmer for pool with a sweeper. only one return.
    Can you take some pictures of your equipment, may thats a return for a pressure cleaner?
    Aug 2010
    San Diego
    18
    Max-e-glass by stay rite (leaking, looking for a Intelliflo VS)
    FNS Plus
    Hayward leaf canister
    poolvergnuegen
    In ground plaster
    Aug 2010
    San Diego
    18
    yeah the plugged hole is for a pressure cleaner but the plumbing at the pump end is gone.
    Anyone have any ideas on what could work?
    In ground plaster
    Y
    There are only a few things you can do with the setup you describe.
    I think you mean "how do I skim and vac at the same time"- and I think the answer is you dont without an LCS which is awesome- or a vac mate (which is junk)
    (Please let me know who had a a polaris LCS left in stock- I clumsily broke mine and its about the best single accessory a suction for a lone suction side cleaner- Ill buy 2 of them immediately.)
    Without return threads you cant plumb in a pool skim which would be great.
    You do have an existing skimmer right? thats where you are plugging in the pool cleaner - is it not placed correctly ie prevailing winds blow away from it?
    About the best cleaning automation you can do with what you have at the moment would be to add a dragonfly skimmer to your setup and commit to a 24x7 pump run. Even then you will be hooking a bottom cleaner up at least once a week.
    To skim and vac without a second line you will need a robotic type setup. There are many reviews on them here.
    Uncle Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    Aug 2010
    San Diego
    18
    http://www.poolsupplyworld.com/pool-.../?cmpid=GS3812
    http://mypoolsupplyguys.com/products...252d-5810.html
    It does not say if they have it or not but it is still available on the web site so it might be worth a try.
    thanks for the input uncle dave
    -b
    In ground plaster
    Why not use a poolskim???
    http://www.poolskimusa.com/
    I want to have this setup in my pool using the "Sweeper you have, however my only concern is the floating chlorine tablet dispenser getting stuck in the pool skim.
    17,000 gunnite, IG, sand filter, 1hp for filter, and 3/4 hp for Pentair IC20 Chlorinator, Legend Platinum II cleaner, installed 2007
    Quote Originally Posted by poolpunisher
    I did not reccomend because his returns are not threaded.
    I have a poolskim as well and would have volunteered it, it will affect flow however- and with a single return may cause issues even if he could fit it on somehow.
    uncle Dave
    I am confused....
    Sorry, I want to get a pool cleaner like he has with the pool skim, however I have 2 lines one for the main drain and one for the skimmer line. plus my pool has 3 returns into the pool. I was gonna use one of them for the pool skim, and use the pool cleaner in the skimmer.
    Is this not ok?
    I am confused....
    Is this not ok?
    that will be fine- one of the best setups you can use.
    Uncle Dave
