Results 1 to 13 of 13
Thread: Goldline Sense and Dispense
    Aug 2010
    Columbia, SC
    96
    My pool was installed with the Goldline by hayward ProLogic setup. There is an option to bypass the Sense and Dispence automation system. Has anyone had any experience with this system and if so what are the pros and cons?
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    el duderino's Avatar
    Jun 2008
    Austin, TX
    118
    Re: Goldline Sense and Dispense
    I have the hayward automation system as well and would be curious to hear some real world reports on the "sense and dispense" as I would like to know if it would help keep my insane ph creep under control.
    http://theaustindude.blogspot.com
    Our pool- (Completed March 2009)
    20k gallons, 38x15 Free Form Gunite (3.5'-8'), 26' Negative Edge and 7' Negative Edge spa with blower, Midnight Blue Diamondbrite, AquaLogic PS-8 control, Goldline Salt Chlorine Generator, 2x1.5hp Pentair 2 speed pumps, Pentair DE Filter, Pentair 400k BTU Heater, and BlackMaxPolaris 280 w/ Hayward booster pump, Pentair Prowler 920, DIY Stenner Chlorinator
    Yes, the PH feed system will keep PH under control quite well. There are other ways to eliminate, or at least greatly reduce, the acid demand even without a PH automation system, but they can take some effort to balance properly. The acid/CO2 feed simply takes care of it. It does add some extra maintenance tasks of it's own (refilling the acid/CO2 tank) but that is not too bad.
    The ORP automation can be much more problematic. Sometimes ORP automation works well, but often enough it causes large fluctuations in the FC level and need to be turned off. Even when it does work, the tradeoffs are more significant, reducing the cell lifetime compared to using simple percentage based automation.
    Aug 2010
    Columbia, SC
    96
    Great! I think I am going to splurge for it and see how it does. Tired of constantly adding muriatic acid.
    Jun 2008
    Austin, TX
    118
    Please come back and let us know how it goes. I plan to talk to my pb about this if and when he ever returns my call
    Quote Originally Posted by el duderino
    Enjoyed your blog, great pool!
    24,000 gal SWG pool
    Bunch of stuff
    Aqua Blue Pebblesheen
    2 Colorlogic LED lights
    Huge Hayward D.E. filter
    more stuff
    Sep 2010
    Orange County, CA
    52
    Sense and Dispense for pH works great for me. I'm really happy.
    I'm reading the ORP posts before seeing if I need to post one myself. It's driving me crazy.
    Southern CA 30K gal Pebble Pentair WhisperFlo 1HP 2 speed Hayward DE6020 filter Paramount Debris Canister Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) Pentair IntelliBrite 5G and GloBrite Inter-Fab G-Force slide Jandy deck jets Lion head spout Dolphin Premier Cleaner Taylor K-2006 test kit
    Jun 2008
    Austin, TX
    118
    seems like the ORP stuff is pretty questionable. Are you using liquid Muriatic or Co2?
    Sep 2010
    Orange County, CA
    52
    I'm using acid, not CO2.
    The Hayward manual recommends CO2. I didn't even know that was an option when it was put it. The pool builder who remodeled and put it in didn't tell me there was a choice. Since I've had some issues and have been talking to some Hayward people, someone there mentioned there were some issues with CO2. Other posts on TFP make it sound like CO2 isn't a terrific idea for residential for various reasons
    Jun 2008
    Austin, TX
    118
    I would be curious to know the problems with Co2. Obviosly there is some danger of them exploding if not secured, but I have Co2 in my kegerator, so that seems like it might be a good option.
    CO2 systems are preferred by some vendors because they can never drive the PH so low that there is a risk to the pool. An acid feed system that gets stuck on can run the PH down to dangerous levels. This is a rare failure mode, they usually break so that acid is no longer being feed. And even if there is a problem you will probably notice it before the PH becomes dangerously low. Still, CO2 systems never have this problem. Continued CO2 injection will simply cause more CO2 outgassing and the PH will stabilize at a safe level regardless of how much CO2 is fed. There is also some minor personal risk when filling an acid tank. The risk of a CO2 tank exploding is far far lower, to the point where you can essentially ignore it.
    Personally, I prefer acid feed. Acid is readily available and inexpensive. CO2 tanks are much less common and end up costing more. CO2 systems are also prone to improper installs, where much of the CO2 bubbles right out instead of dissolving in the water. And finally, acid lowers the TA, which tends to reduce the rate at which the PH rises. In a typical install the PH will get more and more stable over time. CO2 on the other hand does not affect the TA. If you combine a CO2 system with high TA fill water, your TA level will go up constantly and thus the amount of CO2 used will continue to increase until the system is overwhelmed and the PH goes up despite the CO2 feed system.
    Don't misinterpret what I wrote. All of these problems are relatively minor/rare. Most people will be happy with either kind of system (assuming you can afford it).
    Jun 2008
    Austin, TX
    118
    The TA of the tap water in Austin (so I'm told) is 60, so rising TA would be a good thing in my case. With the massive amounts of aeration I constantly get (due to negative edge and skuppers), my TA is hard to keep maintained at a high enough level. This of course is a major contributor to my constantly rising PH issue. Based on what you're saying JasonLion, the Co2 might actually be a better solution for me. I'm not sure how long a C02 tank lasts or if it's feasible to go that route. I would still be interested to hear some of the other issues associated with that route. From a safety perspective, I would feel comfortable either way. In the VERY brief conversation I had with my pool builder, he indicated a preference for acid system, but didn't elaborate on why.
    Oct 2007
    Valrico, FL
    542
    There was post a year or so ago from someone that was using a CO2 system to control pH. Their experience was that the CO2 caused the TA to raise.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
