Results 1 to 9 of 9
Thread: Spa Frog
    Aug 2010
    Columbia, SC
    96
    Spa Frog
    I have a new (last year) fiberglass spa and when I purchased it the dealer gave me the 'Spa Frog' system. I have been using it as stated but I don't sem to have water that is quite as clear as my old bromine tab spa. What are the thoughts of this mineral based system? What are the guidelines for maintaining chemistry with these?
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Spa Frog
    I'm not a fan of the Frog in general, but some use them in spas with more success than pools. You still have to maintain proper levels tho. Can you post a full set of results from the spa? How are you testing?
    You can read about mineral ionizers here:
    http://www.troublefreepool.com/alter...uth-t3025.html
    Aug 2010
    Columbia, SC
    96
    Re: Spa Frog
    I was told that I would need to maintain very little bromine if I used the frog. Lately I have been maintaining normal levels with the floater and basically treating it like a bromine dispenser. I'm thinking when I use up my CASE of bromine cartridges I will let the frog leap on out of the spa.
    Aug 2010
    Columbia, SC
    96
    Re: Spa Frog
    And I am testing with a Leslies/Taylors kit, a DPD kit. I will test tomorrow and post my results. Still trying to get the hang of all this teating and chemical stuff for the pool and the spa. UGH!
    11,969
    Re: Spa Frog
    Quote Originally Posted by kgriggs
    We were all "told" alot of things. Most of it is pure hogwash.
    I'd ditch the frog - it's expensive to replace the mineral cartridge and honestly - you don't need it.
    Aug 2010
    Columbia, SC
    96
    Re: Spa Frog
    Today's test:
    Taylor's drop test:
    Total Bromine 4
    pH 7.8
    TA 90
    Dip tests:
    Hardness 180-250 (2 tests)
    CYA 30
    TDS 500
    Aug 2010
    Columbia, SC
    96
    Re: Spa Frog
    Any comments? Are there any good guides on here for spa chemical balance?
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Spa Frog
    Using Bromine in a Spa
    Using Chlorine in a Spa
    Your numbers look good. Read the bromine link above for more info. It didn't sound like you initially created a sodium bromide bank and just started with bromine tabs so you might not be able to create enough bromine by shocking with chlorine or MPS at least at first. So if you skipped that initial step, you could add some sodium bromide to the water to be sure you have enough. Just remember that the floating feeder isn't going to give you enough sanitizer/oxidizer to handle your bather waste. It's designed to handle the times when you aren't using the spa. You need to add chlorine or MPS after your soak to handle your bather waste. A rough rule-of-thumb is that every person-hour of soaking in a hot (104ºF) spa needs around 5 fluid ounces of 6% bleach or 7 teaspoons of MPS. This assumes that you don't have an ozonator. With an ozonator, the amounts that are needed are roughly half. These are just guidelines and you should use your test kit as a guide to whether you are adding enough.
    Aug 2010
    Columbia, SC
    96
    Re: Spa Frog
    Thanks for the help. So much to learn and try to keep straight!
