Results 1 to 10 of 10
Thread: cracked sand filter tank
    After two failed attempts to repair a crack in the seam of my sand filter, I am turning to the pros! What I have is a plastic tank (150 lbs) sand filter with about a 3/8 split in the seam. I'v tried 2 part epoxy, and quick steel on both the inside and outside of the tank and both have failed within seconds of turning on the pump, both just peel (epoxy) and break (quick steel) off the plastic very easily like its not adhering to the plastic (yes i sanded it first). So... does any one have any idea of a way to fix this? I am leaning towards fiberglass, but not too sure if it will stick to the plastic ? what i really need is something that chemically bounds too the plastic, if such a products exists. Any help is greatly appreciated...
    24' x 48" Delair AGP (11,894.40 gal)
    Pentair Tagelus TA60D 24" (325lb) sand filter in tandem
    with Hayward 75 sf. cartridge filter
    Hayward power flo matrix pump 1hp
    Pool rover Jr.
    Taylor K-2006
    22,553
    Re: cracked sand filter tank
    It's a pressure vessel so not only are you going to have a problem finding something that'll hold you really shouldn't try and repair it. I hate to bear that news but you should just replace it.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Plastaid might work. Fiberglass is cheaper for the amount. I'd just get a new filter though it's not worth having to worry about the patch breaking when your not home
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    30,431
    My filter expands and contracts when the pump is turned on and off. I assume all but the stainless steel ones do as well. That makes it tough for any kind of patch to hold up.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Try sticking a piece of PVC on the inside with a Modified Silane Polymer. We call them pool plasters The plastic will spread the load to the surrounding area of the tank and hold together your glue.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    wow, i haven't thought about the leaving the pump on while no ones home part... i guess that changes things a bit. i don't think i need any thing else to worry about while away so i guess its time to go shopping for a new sand filter thank you everyone for the help, you guys just saved me a big headache in the future i think
    Pool rover Jr.
    Taylor K-2006
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Should you decide to go with a new filter, I would strongly suggest upgrading to a 250lb sand filter. it will cut down on backwashing and improve your flow rate
    30,431
    For emphasis, I want to agree with dmanb2b. You'll never regret that.
    Quote Originally Posted by dmanb2b
    I'm more than likely going to do that but I'm also contemplating going with a cartridge filter instead of sand ? I'm still in the research stage so i am definitely open to opinions at this point...
    Pool rover Jr.
    Taylor K-2006
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Either will do great...here is a a Great example of sand filter water your veryl welcome for the plug, dave!
    water-clarity-and-showin-off-just-a-little-t23969.html
