Results 1 to 9 of 9
Thread: Day One - First Pool
    rgividen's Avatar
    Jul 2010
    Fairfield near Cincinnati OH
    8
    just finished installing our new doughboy, 21 x 41 AG pool - our first and wow, we are excited! as we are not yet up to TFP speed, we took a day one water sample to the pool store - the water in the pool came entirely from the city/county public drinking water system. the pool store test results:
    CYA 0
    Total CL .4
    Free CL 0
    pH 7.4
    Tot Alkalinity 42
    Hardness 114
    she gave us the following items to put in the pool in this order, 30 min apart -
    12 lbs Adjust Alkalinity
    1 1/2 lbs Adjust pH
    5 gal 10% CL
    Stabilizer 8 lbs (i did not take the algacide)
    we put everything in 2 days ago ... the water looks / feels clear / great and we have been swimming both days.
    tested w/ a Pentair test kit (only one in the store - we have ordered the Taylor TF-100):
    CL 3
    pH 7.6
    alkalinity ... tried twice and it seems to come in at 150 ppm ?
    so ... how do we get to TFP methods from here?
    thanks for the awesome site.
    Fairfield, near Cincinnati OH
    26,000 gal. 21' x 41' oval (48" to 7' ext deep) AG vinyl, Pentair 1.5 hp/ 60 gpm, Sand Dollar SD60 200 lb sand filter, Rheem 6350ti-a Heat Pump, OH
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Day One - First Pool
    You are already there...
    It sounds like they screwed up the Alkalinity test. Given the 12lbs of Adjust Alkalinity (you could have used baking soda) your TA should only be around 70
    Given the 8 lbs of stabilizer your CYA should be around 30. If you get a lot of sun on the pool you may want to bring this up to 40-50.
    You are using liquid chlorine, which is fantastic.
    You will find that your pH rises when you are using liquid chlorine with high TA, so you will probably need muriatic acid soon. Whenever the pH gets over 7.8 add enough to bring it down to 7.5 and your TA will come down slowly.
    Other than that, congratulations!
    ETA, what was the "1 1/2 lbs Adjust pH"? Your pH was fine at the time, and there is no such thing as "pH adjust. It is either pH down (acid) or pH up (base).
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    rgividen's Avatar
    Jul 2010
    8
    great to hear. thanx
    rgividen's Avatar
    Jul 2010
    8
    i think it was to 'lower' ... upon re-reading the test results (handwritten) pH may have been 7.9 - this would make more sense?
    30,419
    Welcome to the forum. Sounds like you're off to a great start. As svenpup suggested, your willingness to learn how to manage your own pool makes you a BBB'r already.
    'Til your test kit gets in, I would suggest focusing on keeping your FC between 2-4ppm (it'll take daily additions).
    Then, post a set of test results and we'll see if anything needs tweaking.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    One more thing occurred to me. You said "we put everything in 2 days ago." Does this include the 5 gallons of chlorine? Chlorine should be added each day to bring FC up to a target level which is chosen to ensure that with FC loss throughout the day FC never falls below minimum. Your target and minimum FC are determined by CYA level. Check out the CYA/Chlorine chart link in my signature.
    Have you familiarized yourself with the pool calculator?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    PH adjust could have been soda ash which would have raised the TA as well....
    rgividen's Avatar
    Jul 2010
    8
    thnx svenpup, duraleigh & frustratedpoolmom - the help is great.
    yes, we were initially told (before TFP) to put the 5 gal of CL in (the 3rd, 3 days ago inclusive). tonight i used the pentair test kit:
    CL - 2.5
    pH - 7.5
    TA - 130
    we have not added anything else - waiting on the TF-100 test kit for accurate readings.
    and we’ve been swimming A LOT - wow, we should have done this sooner!
    30,419
    Nice work keeping some FC in there....stay with just what you're doing 'til you get the kit.
    ESPECIALLY nice work on enjoying your new pool. You will be a terrific BBB'r
