Results 1 to 15 of 15
Thread: Bargain Salt
    Bargain Salt
    Stopped at the local Menards to get some salt for the pool today! (Menards is another big-box hardware store for those not around here.) Found some "99.8% Pure Salt" coursely ground, no additives, etc etc etc... It was $3.98 for 50 pound bags. Sounded like a good deal!
    Dumped it in the pool, started to spread it around, and discovered what the other .2% was!
    There's still a few stones in the pool, gonna have to go diving for them...
    Ahh well, shoulda stuck with a name brand!
    Just another excuse to jump in the pool!
    I put in 150 pounds. I know the start level probably wasn't at zero, and I know I should've checked the salt level before dumping it in, but I'm going to be draining it below the return in a few weeks when I close. Theoretically if it was at zero, I should only be around 1700 now, minus the rocks.
    I'm planning on putting in a SWCG next year. So I should be at an ok level to deal with next spring. Looks like I may be gone a few weeks at a time next year. Trying to get into the national disaster medical assistance team as a "Geek" I have no official medical licenses of any sort, but they need a computer/communications geek. Plus it probably doesn't hurt to know the local commander. Gotta do something about the pool while I'm gone! Either swcg or liquidator... Haven't made up my mind yet.
    Ok, back to the rocky pool!
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    Mar 2010
    Mobile, Alabama
    34
    Re: Bargain Salt
    Well, hats off to you for being willing to try it and share with the rest of us! Guess you could always pour it through a skimmer sock next time to catch the rocks.
    16x32 IG vinyl liner, ~19K gallon, built with my own blood, sweat, & tears!
    1 hp Water Ace pump, Goldline Aqua-Rite 40K SWG
    300# Hayward sand filter, dual skimmers, pool open 12 mos/yr
    Re: Bargain Salt
    Turns out there was only one more rock in the pool. The other rocks I saw were white and vanished. So I grabbed one of the white rocks you see in the picture and squished it between my fingers... It was salt. The black ones are definitely rocks though. So it's not as bad as I thought it was, and the water definitely feels nicer now!
    Rob B
    Jun 2007
    Arlington, VA
    29
    Re: Bargain Salt
    I've also had rocks in name brand solar salt, mostly Morton's, not so much the Diamond Crystal.
    ____________
    34,000 gallon pool with charcoal Marquis aggregate finish
    Jandy stealth pump, cartridge filter and Aquapure SWG
    Solar heating with Goldline controller
    Polaris 380 Blackmax
    Jul 2010
    IL
    201
    Re: Bargain Salt
    I used that salt also and found the same thing as you. No biggey though just took a dip and puled the rocks out.
    24' AGP Sentinelle 54" , 1hp 2 speed power-flo matrix, New 250K to replace the 150k BTU heater, pool roover Jr. Aqua Trol SWG, Large deck, taylor k-2006, Majestic Stairs with colored LED, COLD BEER
    Central Connecticut
    159
    Re: Bargain Salt
    I recently installed an SWG in my pool. I had to add about 16 bags to get it started. I bought 8 bags of Diamond brand (all the store had) than saw that Home Cheapo had Morton on sale .. so I bought a bunch of those. Dumped the Diamond brand in. It dissolved nicely with not a hint of stones. Dumped about 4 bags of the Morton brand in and noticed a lot of sand/small stones in the pool. Took a dip and cleaned it up. Than I took all the remaining bags and returned them to Home Depot. Waited a couple of days for the Diamond brand to come in at the store where I got the original 8 bags. Got the Diamond brand and all was clean. I will only buy Diamond brand from now on! I especially recommend it for those who are just prepping for a new SWG and will be dumping many bags in.
    Another plus is that Diamond has a tear apart corner, so that you don't need a knife to open it and it is easy to pour out.
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Southern Indiana
    84
    Re: Bargain Salt
    better to have rocks above your liner than rocks behind and underneath the liner as I have....
    25 K gal, vinyl, IG, next to forest,liquid chlorine and tab chlorinator backup,55gpm sand filter,1.5hp pump
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Bargain Salt
    I bought the cheap-o "everyday living" from Kroger. No rocks in mine...and 3.75/40 lb.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Bargain Salt
    Quote Originally Posted by richmgreen
    Dumped about 4 bags of the Morton brand in and noticed a lot of sand/small stones in the pool. .
    Is this what you bought that had sand/stone in it?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Re: Bargain Salt
    <snip!> Got the Diamond brand and all was clean. I will only buy Diamond brand from now on! I especially recommend it for those who are just prepping for a new SWG and will be dumping many bags in.
    Maybe this is why it caught me off guard when I found rocks. I've only ever bought diamond brand for my water softener. Never seen one rock! ...and of course that tear corner is awesome!
    Rob B
    chessie6's Avatar
    East Hartford, Connecticut
    187
    Re: Bargain Salt
    And here I come to say that the 40 lb bag of Diamond coarse salt that I added to my pool the other day added a few black, tiny pebbles :P
    No biggie - I just vacuumed them up and they ended up in the skimmer sock. However, I cut the tip of my thumb on a piece of sharp salt and I have to tell you that my thumb has been in agony for the past few days . . I've soaked it and put antibiotic on it and nothing would stop the pain. It's finally a bit better today
    Jan
    Summer: 19 x 37 Pacific Graphex IG modified oval, aztec marine vinyl liner, 24,000 gal, 3.5 feet to 8 feet, 1 hp Hayward C4025 Swim Clear 4-cartridge filter, 12.5% Liquid Pool Shock for sanitizing, 1 super wide mouth skimmer, 4 returns (2 therapy jets in steps), Hayward Heat Pro heat pump, non-curved pool slide, 6' jump board, 8 ml blue solar cover, TF-100 test kit, had pink algae in 2010 Winter: Hot Springs Vista Spa, 500 gallons.
    Central Connecticut
    159
    Re: Bargain Salt
    BK406. Yes that is exactly the Mortan salt I bought.
    Re: Bargain Salt
    Quote Originally Posted by chessie6
    Jan
    You must've got salt from the bottom of the pile.
    Rob B
    Dec 2009
    2,690
    Re: Bargain Salt
    Wow, i've never had a problem with that salt having anything in it other than salt.
    chessie6's Avatar
    187
    Re: Bargain Salt
    Quote Originally Posted by Kias
    Jan
    LOLOLOL
    Wish I had saved them - I could have figured out how to string them together into a necklace or whatever
