Thread: Grandchildren, pools, and bodily functions
    Mar 2010
    Ridgeway, SC
    25
    It occurred to me this weekend that I've neither seen nor understood the impact of the old "peeing in the pool" issue. I have 6 grandkids (and a couple of slovenly brothers and in-laws), and while they all say they wouldn't dare, I noticed over a several hour span that I was the only one that ever had to use the facilities (I like the shrubbery on the north side of the house, but Ms Dogface really raises h*ll and says I'm drawing flies! The idea!). So, I suspect chlorine demand goes up... and, as needed I add bleach, but, are there any other conditions/requirements?
    I read the string started by Chem Geek in 2007..... that was an hour ago, and I just got the hysterical laughing under control enough to write this....
    FC - 4.0
    TC - 4.0
    PH - 7.5
    CYA - 85
    TA - 110
    CH - 370
    17,000 gal fiberglass. 1.5hp pump, Pentair 60 sf DE filter and Pentair IC-20 SWG, TF Test Kit, BBB
    Feb 2008
    Denton, TX
    5,061
    Re: Grandchildren, pools, and bodily functions
    Not really, just make sure that your FC doesn't fall below minimum and you will be fine.
    22,551
    You need to read the thread last year by '8cornflakes' for a good report on what "No P in the ool" really means.
