Results 1 to 8 of 8
Thread: Stains versus Mustard
    Jul 2010
    Houston,TX
    38
    My pool is crystal clear and the overnight FC does not change. All drop test are normal except CH is 360
    In the deep end I see a couple of spots that are brownish/yellow. These spots do not change when I brush them with a wire brush and do not appear to be growing or changing.
    How do I differentiate between stains or MA? If stained how do I get rid of them?
    17,000 gal in ground with spa, wet edge surface, Paramount PCC 2000 in-floor cleaner,Pentair Clean and Clear Plus 520 Cartridge filter, 3 hp Pentair Intelliflo VS SVRS pump , waterfall with 1 1/2 hp booster, Del ozone Eclipse1 ozonator, puck feeder. Borates added 8/2/2010
    South Central NJ
    3,192
    Re: Stains versus Mustard
    MA would brush off.
    A complete test results is needed. Your hardness level is a bit on the high side and if the pH and/or Alk levels are too high, scale will form.
    Scott
    Owner of - PoolGuyNJ LLC
    Feb 2008
    Denton, TX
    5,061
    Agree with PoolGuyNJ in that we need to see the test numbers.
    Are the spots in question raised? Any chance that they could be metal stains?
    Jul 2010
    Houston,TX
    38
    OK here are the results. FC 7.5 put in 2 quarts at 4pm. CC 0.5 pH 7.5 T/A 130 CH 320 CYA 50 Temp 91 degrees
    The spots don't appear to be raised. I haven't used any copper based algaecides but I am not aware of metal in my water but I guess they could be metal. How can I tell?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Hold a Vitamin C Tablet on the stains. If they are iron, they will fade rather quickly. If they are copper, they may change in appearance or darken...
    A trichlor tablet held on the stain, if it fades, would mean the staining is organic.
    Jul 2010
    Houston,TX
    38
    These spots are in the deep end. How long do I hold the different substances to the spot?
    11,969
    Vitamin C will work almost immediately if its iron. The others could take longer. You may have to try to figure out a way to hold the tablets on the spots...
    South Central NJ
    3,192
    Crush the tabs, put the powder in a nylon sock with a rock in with it to hold it down.
    Added:
    I suspect scale though. If nothing happens with either the Vit. C or trichlor tab, it's a good bet.
    If you could post a pic...
    Scott
