Results 1 to 12 of 12
Thread: First test with TF-100 - 08/04/2010
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    After receiving wrong data (inconsistent and impossible I think) from the local pool store and not having a reputable test kit, I have my first test results with the TF-100 as follows:
    FC: 4
    CC: 0
    TC: 4
    pH: ~6.8 (maybe less!)
    T/A: 150
    CH: 80-90 (a little subjective I'd say)
    CYA: less than 20 (still slightly visible after filling completely)
    Temp: 78 deg. F
    So, is that FC too high or okay?
    I know my pH has to come up, so gonna go work on that now.
    TA is a little high, but not appreciably...leave it alone for now?
    CH seems a little low, but not appreciably...leave it alone for now too?
    TIA!
    Chris A.
    20x40 36k gal IG vinyl pool w/diving board & slide | 1.25HP Pentair Challenger motor & pump | 30" Triton TR100 sand filter | Pentair SM-20-3 multiport | Stenner 45MHP2 Peristaltic Pump & 13 gallon carboy (BBB) | Hayward CL200 Tablet Chlorinator (used on pool startup) | TF-100 | 2003 Sundance 850 Altamar hot tub
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: First test with TF-100 - 08/04/2010
    You have enough TA that you don't need to add anything to raise pH - just aerate it.
    Others will chime in soon about proper FC for your CYA. (Which also needs to come up, BTW)
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    Since my TA is a bit high and pH is low, best to just aerate to raise pH then? I have plenty of Soda Ash, but that will raise my TA by 60 (according to TPC). Since my pH is already low, assumption is to just aerate, right? How long, approx, will it take to raise the pH if aerating? We have a big pool party planned for Saturday (weather permitting, dang-it) so what would you suggest? FYI, I am currently using Trichlor 3" tabs so CYA should start to rise. Since we have the party planned, would it be okay to just leave the chlorine on the high side to account for the anticipated high bather load?
    Chris A.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You should raise your pH with borax. Since you're using trichlor tabs, the pH will not go up (at least not very quickly). They are very acidic. Borax will not raise your TA as much as soda ash, but since you're using trichlor I wouldn't worry about it at all.
    How long have you been using tablets? Your CYA is pretty low to have been using them for any real length of time.
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    We just replaced the liner a month ago, so it's all brand new water and chemicals, hence the ultra-low CYA.
    Chris A.
    Oct 2009
    3,899
    Got it
    As long as you're using tabs, you'll probably have to bump up your pH fairly regularly. Borax is the way to go.
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    Since my TA is on the high side, don't I need to worry about that too, even with the Borax? I also have Muriatic Acid, but of course that will lower the pH too. Sounds like the best long-term solution is to aerate for raising pH, but that may take too long to get it up by Saturday.
    FYI, I do plan to move over the the BBB method as much as possible when I run out of the existing chlorine tabs (I also have 40 lbs of granular...don't ask why).
    Again, thanks for the feedback!
    Chris A.
    Oct 2009
    3,899
    There are 2 situations where you should be concerned about TA: constantly rising pH (annoying), and high CH+TA+pH (scaling). You don't have either, so your TA doesn't really matter. Once you're done with the trichlor, if your pH starts to rise annoyingly fast, then you could intentionally lower it.
    I still vote for borax; I don't think aeration will cut it when you're still on a trichlor diet.
    30,431
    Use Borax to get your pH up around 7.5. Disregard TA for now.
    As MITS said, you will probably have to use borax again because the pucks drive the pH down.
    It will take you the rest of the season to get CYA up to an appreciable level (50 or so) using just pucks. That's okay, as long as you realize you will consume more FC than if you added CYA seperately.
    I would try to keep the FC level around where you are....4ppm. You are losing a lot to the sun and you never want to be at zero.
    Anticipating the high bather load is VERY smart. You are rapidly becoming an accomplished BBB'r.
    ChiknNutz's Avatar
    Jul 2010
    Arlington, WA
    145
    Clearly, I must have misread the pH reading this morning. After using The Pool Calculator, it said I needed approx 8 boxes or Borax (634 oz.). I put in 4 boxes, mixing about 1/2 box per 5 gallons of pool water, then dumping mostly in the deep end. We then waited a while, then were in the pool for a couple hours. I re-tested the pH a few minutes ago and to my surprise, it read 8.2...twice! Not sure what the heck happened, so I have now added 2 qts of Muriatic Acid to bring the pH down. I hate to alter the water chemistry this much all in the same day, but I must have hosed the first pH reading somehow.
    Chris A.
    30,431
    Miscalculations happen all the time....no big deal. When you're fairly new, it's not a bad idea to check your dosages by asking here on the forum. YOu'll get quick confirmation of any error (or correctness)
    As an aside, I put Borax (and all powders) thru the skimmer. Poured slowly, they are quickly introduced into the system and there's no need to pre-mix or worry about stuff settling to the pool floor.
    Jul 2010
    Pt. Arthur, TX
    174
    Quote Originally Posted by ChiknNutz
    FC: 4
    CC: 0
    TC: 4
    T/A: 150
    Temp: 78 deg. F
    TIA!
    just curious, with those numbers, how does the water feel? Do your eyes burn? is your hair stiff when you get out?
    Custom Cloud shaped 19'x35' - Raised Spa 6' diameter
    Rainbow 320 Inline Chlorinator - Paramount Clear O3 Ozone Generator
    Hayward C4025 Cartridge Filter (Hayward CX880XRE) - Hayward Tristar 2 speed pump
    Hayward H400Fdn Heater, Hayward GVA-24 (valve actuators)
