Thread: New member, introduction
    Aug 2010
    Pekin, Illinois
    8
    Hi, I am a new member. I live in Central Illinois, near Pekin, Il. I live in the country. I have well water that seems to cause me problems with my pool. I have an above ground 24' round pool, about 14K gallons. I have a 1hp sand filter(150lbs). I have been using Trichor pucks for chlorine, but I am going to start using the sodium hypo. as Menards now has the 12.5% gallon jugs for 1.99.
    24' round, above ground, 1hp 150# sand filter, live in the middle of corn fields, have well water
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New member, introduction
    Welcome to TFP
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Hi, I'm new here too and also live in a rural home with well water. What sort of problems ?
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
