Thread: Adding more than one chemical
    Mar 2009
    Charlotte, NC
    539
    Any restrictions on adding pool chemicals when several are needed. Example: you need to acid & bleach & baking soda. All at once ok? I usually add acid, wait 10 minutes then bleach then B soda. Need I wait?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Re: Adding more than one chemical
    You should wait at least a few minutes between chemicals. The only major restriction is to not add CH on the same day that you add anything that raises the PH (PH Up, soda ash, washing soda, borax, baking soda, shocking, etc).
