Results 1 to 7 of 7
Thread: Strainer Lid Help Please?
    Can anyone tell me where I can order the lid that goes on my strainer bucket at the pump...We have replace all the gaskets and the pump is still sucking air...I would like to find a place that has fast shipping...I used poolcenter.com to order my gaskets...they were pretty fast...
    my pump is a old Hayward # sp1807X10
    Thanks
    Legacy Rectangle AGP, 13' x 25', 11,200 gal
    Hayward Power-Flo Matrix Pump, 1.5 hp
    Hayward XStream Filter, 150 sq.ft.
    Mojave Desert Heating System 8-)
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Strainer Lid Help Please?
    Check your front fitting and skimmer hose for leaks. Try a local pool company sometimes they have used ones at a bargain
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Thanks...We have checked all of that and don't see any leaks...but my hubby is going to get all new pipe fittings today and change them out...just to make sure...the pump will pick up then loose pressure...so there is something wrong somewhere...just hope we don't have to break up the concrete
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    So, it's intermittent? Have you checked your skimmer weir (flapper)? If it sticks a little, your skimmer can intermittently suck air.
    I will mention that to him this evening...he put pressure on the lines yesterday and found 2 leaks...fixed those, things are better but still not right...
    Jun 2010
    NE Ohio
    70
    Did you manage to get the leak stopped? All I can offer is that my Hayward Flow matrix (a little different from yours but has an o-ring seal) is a total PAIN to seal. My lid twists on so if I twist too tight it leaks, not enough torque it leaks...all I know is it needs to be swimming in lube before it seals properly.
    Peter
    21' X 52" above ground
    1 HP Hayward Power Flow Matrix Pump
    Hayward EC40C DE Filter
    We did get the leak stopped...Hubby found a bad crack in the pipe...it was in a joint...did have to knock out a whole in the concrete..but wasn't too hard...I also ordered a new lid for the strainer bucket...I put that on yestereday...everything is working great!!!
    Thanks for all the help from this forum
    Shielda
