Thread: adding salt to your pool
    Jul 2010
    col. Ohio
    15
    I went in an inground pool that had salt water for the first time. I was just wondering what is involved with changing over from reg. water. i also read you ca add salt to reg water pools without totaly converting to salt. Is it really benificial to convert. or can i add some salt to soften my current water.
    10,000 gal. above grnd.
    300 # sand filter
    solar cover(do not use often)
    May 2009
    Dallas, TX
    785
    Re: adding salt to your pool
    This is just one of the gems in Pool School. It is found under the "Further Reading" section at the bottom of the page.
    Adding Salt to Improve the Feel of the Water
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
