Thread: Paramount PCC 2000
    Jul 2010
    Houston,TX
    38
    Paramount PCC 2000
    My in-floor pool cleaner has a main drain and 90 degrees out from that has two pop ups that shoot water back towards the main drain. I also have a VS pump. I have noticed that these two pop ups pop up all the time while the pool is filtering not just when the cleaner is working (which is when the other floor pop ups open). I have also noticed that the pop up require about 2200 rpm before they activate( I don't know the flow).
    If the pop ups are working does that indicate that there is enough flow to push debris to the main drain or am I going to have to keep the VS pump running higher than 2200 rpm to increase the flow?
    I have been running at 3000 rpm for 10 hrs a day but was going to experiment with bringing the rpm's down to save on electricity. I had hoped to run at 1000 rpm's for 24hrs but that looks like it's not going to happen.
    Thanks for you comments
    17,000 gal in ground with spa, wet edge surface, Paramount PCC 2000 in-floor cleaner,Pentair Clean and Clear Plus 520 Cartridge filter, 3 hp Pentair Intelliflo VS SVRS pump , waterfall with 1 1/2 hp booster, Del ozone Eclipse1 ozonator, puck feeder. Borates added 8/2/2010
    Re: Paramount PCC 2000
    I have the Vanquish system and as a new user had some questions. I e-mailed Paramount and received a reply within a day with some very useful info. I took this info with what I learned on this site and everything seems to be running well, knock on wood.
    Good Luck
    Kurt R
    35900 gal. 20x40 Inground, Vinyl Liner with Deep End in the Middle, Roman Stairs on Both Ends
    Sta Rite Sys 3, Hayward 1.5 Super Pump, Aqua Heat Heat Pump, Paramount in Floor, BBB
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    I also have a PCC-2000 system and your understanding of how the system works is correct. The 2 fixed nozzles that point to the main drain are controlled by the main filter pump and not by the cleaning system. I have our intelliflo VS pump set to 1900 RPM's for normal filtering and the heads pop up about 3/4 of the way. They are pushing debris to the main drain but probably not as efficiently as designed. However, I run my cleaning system for about 3-4 hours per day. During this time the Intelliflo RPM rises to about 2,300 RPM's which fully open the fixed nozzles. I have found that my pool stays very clean running the cleaning system for that amount of time. I just assume that when I'm running at normal speed, the fixed nozzles are essentially just returns. If they push some debris great, but hopefullly, all of the debris has been cleaned and there's nothing left to push to the main drain.
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
