Results 1 to 8 of 8
Thread: UV?
    solarboy's Avatar
    Aug 2010
    Europe
    337
    UV?
    I'm just wondering what anyones thoughts were on UV for chloromine reduction. I was originally going to fit UV and a chlorine tab feeder until I found this site and realised my CYA would hit maximum too quickly. So I am now thinking of using SWG and am thinking that maybe the UV won't be needed because the chloromines won't be produced. I'm still new here and I have noticed how little anyone speaks about chloromines. I was led that these were an inevitable result of using chlorine and that shocking broke these DPB's back into chlorine? Yet a lot of people here say that if you mantain proper FC all the time ( ie with a SWG or careful testing and dosing) you should never need to shock. These two statements do not sit well together.
    Another semi-relatedpoint, when you run with higher CYA and therefore a higher FC level, is your CL consumption higher or is it just that you maintain a higher level and usage remains the same?
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: UV?
    UV does help break down chloramines, so it can be useful in an INDOOR pool where there's no sunlight exposure. Outdoors, you get plenty of UV for free already, so it's a waste of money!
    Typically, higher CYA means you lose less total FC to sunlight, i.e. your FC demand is slightly lower.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: UV?
    We talk about chloromines all the time...we refer to them as CC. High CC (>0.5) is one of the indicators that shocking is needed. Shocking does break down CC's, but so does sunlight. So a well maintained outdoor pool, where FC is always maintained above minimum for the CYA level, shocking is not needed because the small amount of CC created is burned off by the sun.
    (MITS beat me...)
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jun 2010
    Glendale, CA
    513
    Re: UV?
    there are some detailed discussions on the chemical breakdown of chlorine but the highlights are
    FC interacts with Organic material to become CC's
    CC interacts with FC and/or sunlight and becomes some form of Salt
    It doesn't turn back into chlorine
    You may be thinking of the Bromine/Chlorine interaction
    Bromine --> Bromide
    Bromide + Chlorine --> Bromine
    Once your pool is clean and balanced - if you maintain the proper FC level then you may never need to shock. With no large accumulation of organics or CC you never outstrip you FC for any length of time - so algae, etc doesn't get a chance to grow.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Re: UV?
    Fantastic responses ! ... Cleared that up for me.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: UV?
    Blue or Cherry?
    (sorry for the offtopic post but I couldn't resist....)
    Southern Indiana
    84
    Re: UV?
    There is a system that uses a combination of ozonator plus a salt water chlorine generator - the ozone oxidizes organic matter as water passes through the system and also chloramines are destroyed - the result is much lower FC concentrations required - we had one for 3 years - when it worked - it worked well - quality control and material defects rendered it a hassle - so, we gave up on it and went with conventional chlorine - BBB all the way. But, I still like the ozone/SWCG idea.
    25 K gal, vinyl, IG, next to forest,liquid chlorine and tab chlorinator backup,55gpm sand filter,1.5hp pump
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Re: UV?
    I've not been anti-chlorine at any point per se, I just love anything that reduces my intervention without costing the earth. I lost a bit of enthusiasm for SWG after a couple of units I fitted for other people had problems but this was mainly due to myself as a pool builder not taking long enough to get to understand them (turned out to be faulty pH sensors and pumps usually).
    Almost certain I'll be going SWG next year, I've just fitted my pH doser.
    Blue or cherry? I must admit I'm at a loss to answer.
