Thread: CC levels
    Henry Porter's Avatar
    Nov 2008
    Sweden
    604
    CC levels
    My CC has ranged from 0 to 0,5 and on the latest test was it 0,5. The pool had then been covered for a while and not been exposed to any sun. CC levels of 0,5 should that makes me increase my FC? Or will a sunny day break it down to zero again?
    My FC is usually solid around 2,5-3 with a cya just above 50.
    Inground concrete pool 14600 gallons,Pentair Whisperflo 3/4HP WFE-3, Hayward swimclear 420sq ft
    Zodiac LM3-24 SWG, Dolphin Diagnostic poolrobot, Heatpump Gullberg&Jansson 13,8KW, TF testkit.
    Seen a shooting star tonight And I thought of you You were trying to break into another world A world I never knew
    I always kind of wondered If you ever made it through Seen a shooting star tonight And I thought of you
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: CC levels
    When your pool is covered, the sunlight can't burn off the CC as it normally would. My CC also slowly rises if the cover is on for a few days. It's nothing to worry about, and should go away once the pool is uncovered for a little while.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: CC levels
    What MITS said
    Nov 2008
    Sweden
    604
    Re: CC levels
    Thanks both
