Results 1 to 7 of 7
Thread: Reducing Cl
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Reducing Cl
    What is the best way to reduce the Cl in a pool without messing up the water chemistry? My Taylor test kit book talks about Sodium Thiosulfate Hydrate-5 being used to reduce Cl levels but I'm not exactly sure what that is and if it affects pH, alkalinity,.... Does this have a more common name or is it in a more common form?
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Sodium Thiosulfate is sold as chlorine neutralizer, see for example here. It would tend to increase PH a little. It is ocasionally difficult to find because it is rare to need to reduce the chlorine level, it is fairly expensive, and sun light normally takes care of lowering chlorine levels without any chemical assistance.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    What Jason said. Stop adding chlorine to the water, and let the sunshine in.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    mas985's Avatar
    Pleasanton, CA
    11,742
    Or get your whole family to pee in the pool.
    Mark
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by mas985
    must....not...make.....chemgeek....reference....here......mu st....fight.....urge!!!!!!!
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by MikeInTN
    What! The ChemGeek thread? .........
    ............but you know, a lot of folks did not have the opportunity to view that...
    ....and you know everybody needs a good laugh!
    Joyce
    You're done SLAMing when:
    Mar 2007
    San Rafael, CA USA
    12,082
