Thread: Building a raised pool
    Aug 2010
    Charleston, South Carolina
    77
    My house is built on a 5' crawlspace and I want to construct a pool at the same level. My house is L shaped and I want to have the pool in the L with decks on two sides and the other two sides open. 16' x 30' rectangular pool with 3' shallow/6' deep . My question is how would the pool be formed. Would you construct it with concrete blocks and then gunite the inside? Build wooden forms and then spray with gunite? Anyone built anything like this before?
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    SCEADU's Avatar
    Feb 2010
    Atlanta,GA
    68
    Re: Building a raised pool
    The pool can be formed up with 2x4's and plywood and then shot out of the ground. I will post some pictures after I restart my machine .
    SCEADU's Avatar
    Feb 2010
    Atlanta,GA
    68
    Here is one that I built four years ago.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Here's another example:
    tennessee-pool-build-t24501.html
