Thread: Reel suggestions
    Jun 2010
    Sewickley, PA
    11
    Reel suggestions
    I'd really like to add a reel to my AGP. Getting the cover off is a pain right now.
    It's an oval 18x33, with a deck at one short end. The deck comes around to the straight part of the longer edge on one side, and not quite that far on the other side (stops along the curve). To further complicate things, there's a ladder going down from the deck.
    I've seen some nice designs that you sink into the ground at the end of the pool, but I don't want to do that - the non-deck end of the pool is right in the middle of the yard, not out of the way at all. Do I really need an AGP reel, or could I get an IGP reel and sit it on the deck? I'm thinking something that I can wheel away from the pool to sit against the back railing when not in use. I'm a bit worried about getting it over the ladder and the edge of the fence, though - see pictures.
    If that's going to work, any specific reel recommendations?
    Pittsburgh, PA
    16000 gallon AGP, Perflex EC40C75 DE filter, 1.5 HP pump
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Reel suggestions
    Not too familiar with AGP reels, but I seem to remember seeing one that straddles the pool and was only anchored at one end, so you could swing it out of the way.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Looks like your cover needs a haircut Sorry...little mid day humor, you may find it easier to handle by trimming the cover to fit inside the pool. Outside of that the brackets work well, but I use FPM's eggroll method. Basically just pull the cover as far up the deck as I can, fold the edges over and roll it up. I swear we need to get a video of FPM doing that.
