Thread: Awesome Aerator!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Awesome Aerator!
    I have seen this driving by the community pool a few times. I don't know if they do it for cooling or aeration, but it looks pretty cool! In case you have trouble seeing it in the video, it is a pool pump mounted on a wheeled base with a line that is dropped into the pool and it has twin pvc sprayers for output aimed into the pool.
    http://s138.photobucket.com/albums/q242 ... CT0049.mp4
    Love TFP? Become a
    TFP Supporter!
    Aug 2009
    North Central Texas
    1,358
    Re: Awesome Aerator!
    Quote Originally Posted by zea3
    That is cool. Do you know what size the pump is?
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Jul 2009
    Houston, Texas
    9,379
    I can't get close enough to tell. Looks like a residential pump from a distance, so probably a 1 or 2 hp.
    Love TFP? Become a
    TFP Supporter!
    Jul 2007
    Suwanee, GA
    528
    My guess the main goal is to cool. I've had better luck getting the water as high as possible, though a slight wind pushes my water around a lot. With enough volume and a finer spray pattern the low trajectory probably works out fine.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
