Results 1 to 10 of 10
Thread: Umbrella- Crank or Pulley?
    deanchat's Avatar
    Feb 2008
    Tidewater, VA
    28
    Hi everyone,
    I am looking at getting a patio umbrella (Fiberbuilt 9' octagon) and a pulley based mechanism seems simpler and more robust. However, my wife is not too tall and I'm worried that she might not be able to reach the pin that is used to secure the canopy, especially since the umbrella will be in the center of a round table. This is making me consider a crank mechanism instead. So, my questions are:
    1) How high does one need to be able to reach in order to operate an umbrella's pulley mechanism, i.e. set the pin. The umbrella I'm looking at is 92'' tall and has a head clearance of 72", but how does that translate how high the pin would be?
    2) Are crank mechanisms reliable?
    3) How slow is (or how much cranking is needed to raise) a crank based umbrella?
    Thanks!
    Dean
    37x16 IG vinyl, about 20K gals
    Pentair FNS 60 DE filter
    3/4 hp Pentair Challenger pump
    1 skimmer, 2 bottom returns + 1 step jet
    AutoPilot Dig 220
    Nov 2009
    Indialantic, FL
    323
    Re: Umbrella- Crank or Pulley?
    I think my wife has enough height, but she found the crank to be easier given her physical strength (setting and pulling the pin requires some tension on the ropes). I ALWAYS had to raise lower the rope/pin umbrella. She never calls on me to raise/lower the crank umbrella. Note: These are/were both large umbrellas - the current crank unit is 11' aluminum structure and the rope one was a 10' or 11' wood unit (forget exact size).
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Jun 2007
    New Jersey
    653
    I agree. I recently switched from a pulley to crank, both 9'. (I didn't really care, the old one wore out after many years--fabric was rotten--and the crank was the right color and price). The pulley required some real arm strength to get it high enough to get the pin in. I'd say height is not the problem, the pin probably goes in at the level of the head clearance--that's how the geometry works out. The crank takes more time, but is easier to do. It's still not a lot of time.
    I have no insight as to reliability of the crank, but you see them a lot at resort hotels.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Feb 2009
    West Virginia
    216
    We have some of each type. I am 5ft2, and I cannot reach the ones that have to be secured with a pin. I have to use a stool, which amuses my DH to no end. So my vote is for the crank umbrellas! They are easy to put up and down, even our large offset umbrellas.
    WV Girl
    Custom "L" shape IG gunite pool, 36K gal., main drain, 2 skimmers, 3 returns, hayward heat pump, hayward 1.5hp pump with booster pump, ozonator, 4 cartridge filter.
    one dear hubby, two waterlogged kids, and lots of good times!
    I recently got an 11' umbrella that is in the center of a table. The crank is so easy to use. I guess I am just lucky that I got this as I had no idea that a pulley was hard for a short person.
    BTW, the umbrella was from Overstock.com, $99 for aluminum pole and 8 fiberglass ribs, has a single wind vent. A screamin' bargain, and I am very very pleased with the quality. It did not come with a cover for winter storage but I can sew a bag for that easily enough.
    Edit - that umbrellas is now $65, colors limited to green, green, and black. What a deal. It is huge and so best in an in-deck hold or base of 65 lbs or more due to the size. Fiberglass ribs are better than other sorts.
    Charleston-Dawn's Avatar
    Apr 2008
    Summerville, South Carolina
    28
    I vote crank. I had the pully and I'm kind of short. 5' 3". I could get the pin set in if I streached and tippy toed but if the wind picked up quickly I had a difficult time getting the umbrella down fast!! Ours was anchored to the wood deck. It has been replaced with a crank . The crank ones seem to handle the weather better too. Our umbrella pulley rope popped due to sun damage.
    It is what it is, and sometimes it's scary!
    AG-22200 gal 45x18x4 - Sam's Wholesale, June 2008
    1hp pump, 19 inch 100 lb. Waterway sand filter (plus DE)
    apx 45 gal per min
    Summerville SC.
    deanchat's Avatar
    Feb 2008
    Tidewater, VA
    28
    Thanks to everyone for the input!
    -Dean
    AutoPilot Dig 220
    Aug 2009
    North Central Texas
    1,358
    I have both. The Fiberbuilt, 11' hole is pretty far up there. I'm 5'7' and I still need a step stool to put the pin in the top hole. The bottom one I can reach without stool. I have pretty good strength but no muscle woman. It does take some strength to get the pulley started and then stretched up to the top hole.
    My Fiberbuilt has withstood many high winds >40 mph in open position, and even came through, without a scratch, an uplift and then slam into the deck rails (taking the table and chairs with it - the wind lifted it up and it hovered above the table for a few seconds - evidently the bolt in base had loosened) during a 70 mph rain storm. It was open.
    I prefer pin but, to tell you the truth all the cheaper umbrellas I've had have been crank and I've only had major problems with the expensive Off The Wall (Half umbrella) crank. The manufacturer replaced the whole unit. I think most of the umbrellas, no mater the cost, have only a one year manufactures warranty on the pole. Fabrics, one to five years.
    With the cheaper umbrellas the fabric goes before the pole and ribs usually.
    I like the tilting crank one but they always lean a little at the hinge when open, but not tilted, and they flap and giggle around more in the wind. I am going to do a post on TFP on ideas for a quick release band to go around the hinge on some of my tilting umbrellas.
    That offer from Overstock is a super bargain for a fiberglass rib umbrella if you can use the colors they have.
    As far as the 11'. In late afternoon, 11' still isn't big enough to shade the table but one adapts.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Jul 2010
    Mickleton, NJ
    229
    Quote Originally Posted by dlduvall
    I'm 5ft2 as well. We have had both. The pulley on just required me to get on a chair to get the pin in. This is only an issue if you have swivel rocking chairs like us so my vote is the crank. However, if I loved a pulley and the price was right I'd get another in a heartbeat.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    deanchat's Avatar
    Feb 2008
    Tidewater, VA
    28
    Thanks for all the great info! I ordered a crank umbrella for my patio table. Next, I will probably get a pulley umbrella to put next to my poolside lounge chairs (it will be freestanding, so no leaning over a table when trying to set/unset the pin).
    -Dean
    AutoPilot Dig 220
