Results 1 to 9 of 9
Thread: horse flies and wasps
    Live in Cache Oklahoma, just west of Lawton. We have a few cows and chickens, however they are 1000 yards away from the house and 1200 away form the pool, this is our first year in the house. How can we lessen the pesty fling bugs?
    thanks
    leisurlee
    22000 hayward pump inground kidney, diving board
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    414
    Re: horse flies and wasps
    I sprayed about 100 gallons of Sevin around our yard and woods -- about 3 weeks ago and I have had no bugs or horse flies. I could not even be outside before.
    The trick I used was to put 1qt of sevin in a 50 gal trash can and filled with water. Then I dropped a small sump pump into the water and attached a garden hose. I was able to reach far out into the woods and get it done quickly.
    Not big on using chemicals, but Sevin is not that bad. They use it in produce/ farms.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    What an elegant and very creative solution to spraying a large area!
    Couple of questions:
    What size sump pump? Do you know the hp of it?
    Did you have any trouble finding the proper connectors to hook a garden hose to it?
    What kind of hose end sprayer did you use?
    Our sump pump is rated for 2000 gph and might blow a garden hose apart but these pumps are fairly inexpensive at Harbor Freight. We're thinking of using your method with weed spray on our property. It sure would beat a pump sprayer.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Kes's Avatar
    Apr 2010
    Worcester UK
    46
    I would advise a little caution. Sevin - apparently - kills all insects known to mankind, good or bad, pollutes water courses, may cause a reaction in mammals, especially dogs, and is banned in many countries, including the UK, Australia and Angola, as a carcinogen. I'm not sufficiently educated to argue the pros and cons of Sevin, but there's a lot of info available online.
    11,000 Imp galls inground hopper 15' x 35', Delifol liner (vinyl), sand filter, Abrisud Classic cover, Palintest 315C test kit
    Quote Originally Posted by blakeusa
    Did you spray 100 gallons, one quart at a time? Or did you use 2 quarts Sevin and 100 gallons of water?? Just curious.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Feb 2008
    Denton, TX
    5,061
    Having cattle, no matter how few, will means that you are going to have to contend with biting flies. Since you have the best watering hole (pool), everything is going to want to flock there even if it is 1200 yards away.
    As mentioned, Sevin does work well but it is expensive when it comes to large broadcast applications. And then, when it rains, all your Sevin gets washed away.
    Have you considered calling your extension agent for suggestions or help? Comanche County OSU Extension Agent can be reached at 580-355-1176.
    thanks MOD SQUAD, I wlll call.
    Aug 2010
    Atlanta, GA
    39
    I usually use cypermethrin and this will work GREAT for wasps. Don't use knock-down spray but order the cypermethrin powder and mix 2 spoons with 1 gallon in a pump sprayer. Cypermethrin can actually be used indoors but it will make you sneeze if you breathe it in. It will leave a very fine white residue as it dries. The key is residual. Anything that says WP mean wettable powder and that's what I usually get. Demon and Cynoff are two brands but I usually get the cheap synthetic/generic. As for horseflies, that's a lot harder. Those guys you need DEET (which everyone will say is bad, but it's really the only thing that biting flies keep away from). For some more infrormation, you can look here - http://www.pestproducts.com/bitingflies.htm#repellent
    I would also order cypermethrin online, you'll pay way too much for way too little at a home depot or Lowes.
    Hope that helps. I'm a new pool owner but i have a hobby killing wasps (I can't stand wasps so I did a ton of research on this).
    40x20 Vinyl Inground (27,000 gal). SWG with Pentair 48 DE Filter.
    Also have a broken Polaris pump with no polaris and a broken AquaCal Heat Pump...inherited from last owner.
    I would second the cypermethrin recommendation. It is an excellent general insecticide. I order it on ebay and spray about a gallon around my house every three months. I think I paid about $12 for enough to make four gallons. That is a year's worth of maintenance spraying for me. From what I read it is the most common maintenance spray used by pest control operators. There are better products for specific applications, but for general use it is relatively cheep and very effective. It also has little or no noticeable odor and is safe around non-aquatic pets once it dries. Sorry if that sounds like an infomercial, but it is good stuff.
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
