Thread: Pump run
    Jul 2010
    Houston,TX
    38
    Pump run
    I have been running my pool pump for 10 hours a day and currently have crystal clear water. I am running at 3000 rpm, which currently gives me 1.9 turnovers/day. I am thinking of running at 1500 rpm for 16 hours which would be 1.4 turnovers/day. Does this sound reasonable? What do I watch for?
    17,000 gal in ground with spa, wet edge surface, Paramount PCC 2000 in-floor cleaner,Pentair Clean and Clear Plus 520 Cartridge filter, 3 hp Pentair Intelliflo VS SVRS pump , waterfall with 1 1/2 hp booster, Del ozone Eclipse1 ozonator, puck feeder. Borates added 8/2/2010
    Re: Pump run
    The usual rule of thumb is to run around 1000 RPM for long enough to do one turnover a day, or a little faster if your skimmers don't work well at 1000 RPM.
    Watch the water clarity/sparkle closely, and give the pool a week at the new run time before making a decision.
