Results 1 to 7 of 7
Thread: Alternatives to A+B Epoxy?
    JoseJones
    Guest
    Well, the ol' swimming hole has been great, but that pesky leak is back. I've used some Marine grade A+B Epoxy I got from the hardware store, but its really a pain in the Watusi to get into the crack in the Plaster. It basically pills up as I apply it -some times floats away moments after I scrape it on. I've tried waiting longer, less, spinning on my head. Same results. Pool is a tasty 86 degrees so it should slather on like butter. But no dice.
    Is there anything else I can try that sticks where I stick it? Color isn't too much of a concern, since the pool is seriously Fugly. That's why we call it the Ol' Swimming Hole!
    Thanks!
    Jose
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Alternatives to A+B Epoxy?
    Ever tried Water weld?
    Love TFP? Become a
    TFP Supporter!
    JoseJones
    Guest
    No, I haven't.
    I was thinking if I could use a sanded expoxy based grout?
    Thanks.
    Jose
    solarboy's Avatar
    Aug 2010
    Europe
    337
    We use these new MPS based sealants, the brand here in Europe is Tec 7.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    I've used a two part epoxy that I got at the pool store, $20, one tube is blue the other is white. You cut off equal portions of the clay-like stuff and mix in your hand, then apply to the crack. It is white when mixed and it sticks really well under water or above. Very sticky, no pilling, no floating.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    We use Tec7 with a butter knife. Squirt a bit on the knife (or small spreader) and then swim down and smear. It comes in tubes like silicon but is 4 times the price. The thing to look out for is MSP in the ingredients. (Modified Silane Polymers).
    I've just found this link
    http://fixtechmarine.com/all-products.html
    They have some of these type products, but I'm having trouble finding US suppliers. Good luck !
    JoseJones
    Guest
    Thanks everybody. I guess the stuff I'm using is much more viscous than what you're looking at. I'll poke around a bit.
    Jose
