Thread: pump output
    Jul 2010
    IL
    201
    pump output
    Does anybody have an idea of how much water the power flo uses in 2hp version? That's what I have its overkill and a power hog. Thinking of going to the 2 speed 1 HP power flo. If I do does anybody know the GPH of that also? I am going to try and dial the SWG in and knowing the flow rate would def help my cause.
    thanks
    24' AGP Sentinelle 54" , 1hp 2 speed power-flo matrix, New 250K to replace the 150k BTU heater, pool roover Jr. Aqua Trol SWG, Large deck, taylor k-2006, Majestic Stairs with colored LED, COLD BEER
    Jun 2010
    Toms River, NJ
    80
    Re: pump output
    The flow curves should be posted on the company website. It's going to depend on your setup also. You may want to read hydraulics 101 to get a fel for pump sizing.
    18'x24' (10,000 gal) above ground pool, 19" Proline sand filter (45 GPM), Jacuzzi 1.5 HP 2 speed pump
    Jul 2010
    IL
    201
    Re: pump output
    took a read and def going to get a smaller pump....
    Jul 2010
    IL
    201
    Re: pump output
    Just ordered the power-flo matrix 1 hp 2 speed pump... I figure this 2 hp will be a good backup or on ebay shortly...
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: pump output
    Sounds like a good plan. You'll save a bunch of money!
