Results 1 to 8 of 8
Thread: Anyone expand their existing deck to their new pool?
    Jul 2010
    Mickleton, NJ
    229
    We have a large Trex composite deck that comes off the house. Our pool was installed about 2 feet in front of the deck. We were originally thinking we'd like to change the deck so that the deck comes right up to the pool and one could enter the pool from the deck, giving you that inground look. I'm wondering ball park how much it will cost to make these changes? I'll post some pictures if anyone is interested in seeing exactly what I'm talking about. Has anyone else done this? If so was it difficult?
    I added pictures below.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    Jul 2010
    Mickleton, NJ
    229
    Re: Anyone expand their existing deck to their new pool?
    Currently Pooless
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    240
    We extended our deck to reach about half way around the pool. Ours is treated wood instead of composite. I'm so glad we did this! Now we can walk out the back door and get into the pool without our feet ever touching the ground. It also makes vacuuming and brushing alot easier than it was before.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Oct 2007
    Cedar Hill, TN
    250
    We connected our screened in porch all the way along the back of the house, to wrap half way around our oval pool on the side of the house. I love it!!!!
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    Our pool was installed by the previous homeowner. When it was first installed, the deck did not extend to the pool. We have a walkout basement, and the yard is 10' lower than the original deck. After the pool had been installed for a year or so, they decided to build a deck for the pool itself. This one is at pool level, and extends around 1/2 the pool. In addition to the original stairs from the upper deck to the patio, they added a stairway from the upper deck to the lower deck, and a stairway from the lower deck to the patio, so there are stairs all over the place. From the photos you posted, it would appear that you won't have that 2-level issue, or only a couple of feet at most.
    I really like having the deck at pool level, but do wish that it went all the way around instead of only 1/2 way. Maybe some day I'll extend it the rest of the way.
    24' AG Round (vinyl replaced 0909) - 13500 gal - Sand Dollar Filter (150lb) - Dynamo DYNII-N1-1 1HP - Hayward HP380 Heat Pump - TF-100.
    Central Missouri
    Before I speak, I have something important to say.
    Jul 2010
    Mickleton, NJ
    229
    Anyone feel like positing pictures? I'm just trying to get some ideas as to what would look good. The deck is about 6 inches shorter than the pool so we could either do a step up or put the deck under the rails.
    Currently Pooless
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,225
    Putting the deck under the rails is good. Then you will have access if you ever need to change the liner.
    Love TFP? Become a
    TFP Supporter!
    TimS's Avatar
    Sep 2009
    Central Missouri
    214
    I agree with Zea on the deck under the rails. Mine was built with the deck about 1/2" below the rails, and the decking is cut around the wall supports so it fits fairly closely to the pool wall. There's a gap of about 1/4 - 1/2" between the pool wall and the deck. Made it really easy to get the rails off when I had to replace the liner last year.
    Central Missouri
