Thread: Control box location?
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Where are you guys mounting your control box for your SWG? My husband feels since our siding is vinyl, it would not be a good idea to hang it on the house. His thoughts are to put it on a post. Idk, I want to hear some options.
    Here's a picture of the pumping station minus the control box;
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    22,553
    Re: Control box location?
    I wouldn't mount it to the siding either but that's just my personal preference. I'd set a panel where that cardboard box is if it's accessible after everything is set. I'd also build some kind of roof over it.
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    That would be at ground level. I think it would be hard to access....wouldn't you agree?
    I do agree something needs to be over it.
    22,553
    Sorry I wasn't more clear.
    I'd mount a couple of post in the ground right by the slab and mount a back plate of either plywood or metal on them and mount the panel on that. I'd put a small cover on the top too. Does that make more sense??
    By mounting two posts and a plate you have room to mount other equipment when you need to.
    Dec 2009
    Central Massachusetts
    2,690
    I'll disagree with the not mounting it on the house. Do what you want, but mounting a box on the side of a house with vinyl is no big deal; it's done all the time. The box for the telephone, cable, electric meter, automatic water meter reader, are basics. In addition to that I have the Easytouch for the pool, and 2 transformers for my low voltage lighting on the house.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
