Thread: Natural Gas hose????
    I just obtained a fairly new natural gas grill. I had a natural gas line installed about 5 years ago when my pool was built, but still haven't used it. The gas line was run directly from my meter at the side of my house. Eventually I'm going to build an island, but for now I just want to use the grill.
    I called a few local hardware stores and they could not tell me how to connect it. they said I needed a tank??? any idea what they are talking about?
    The pipe coming from the ground is much larger that the one coming from the grill. I am not sure how to measure it to see what size hose I need.
    I assume All I need is a hose? do I need a regulator?
    Can you please enlighten me, so I can purchase the correct hose. Also is there a reason for the quick disconnects? don't you leave it connected all the time?
    Thanks for your input.[attachment=0:e494ioqx]0801001402.jpg[/attachment:e494ioqx]
    11K gal, in-ground 15'x33' San Juan Fiberglass, Pentair Whisperflo 3/4 hp pump, Pentair Clean & Clear Plus Filter CCP320, Pentair Inteliclor 40 SWG,
    Jul 2010
    SE Alberta, Canada
    23
    Re: Natural Gas hose????
    Natural gas BBQs usually come with the appropriate hose and quick coupling you need to connect to the line. If your's is used, you can likely use a quick google search to find the manufacturer's part number of a replacement. Generally though, any good BBQ store should be able to 'hook you up'. A regulator isn't needed, but most places require a valve on the line (I see you already have that) and a quick disconnect at the supply end.
    15x33x54 Oval AG
    15000USG
    Hayward 3/4hp pump
    Hayward 22" sand filter
    BBB
    Guest
    That looks like a well run line (tracer wire is there, shut off already on). You should be able to pick up a bell reducer at any hardware store (HD, Lowes, etc.) and flex line to finish the connection. Then all you need is an adult beverage and some dead animal to make for a nice evening
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    The natural gas grills that I've seen use a 1/2 inch line. So you'd need to reduce to a 1/2 line and get a 1/2 inch disconnect/adapter and hose. I believe if the grill required a regulator, it would come with it, and would be right where your disconnect hose would connect to. I think the manufacturer wouldn't want you to use any regulator because of liabilities.
    The guy who mentioned the tank must be thinking about propane instead.
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
