Thread: grrrrr...Did I mess up?
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Hi everyone
    I have maintained a "sparkly" pool since my baq conversion last summer and all my numbers have stayed in check until recently. They weren't horrible , but I noticed my TA had fallen to about 80 and I always kept it at about the 110 range. So I used the pool calculator and bumped it back up, but I must have overshot because now I am reading 130.
    Is that too high, will it hurt anything, should I lower it and if so how?
    oh, here are my other numbers
    FC 6
    CC 0
    PH 7.5
    TA 130
    CYA 40
    Thanks so much, you all have been great!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Re: grrrrr...Did I mess up?
    Might be clear to others from the specs in your signature, but can you specify if it is vinyl or other finish? Specifying that will help someone who knows about TA -- hopefully someone will be along to respond shortly - that is out of my league.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    30,432
    Hey, pepsiholic,
    I'll bet your fine. Leave your TA alone and keep a slightly closer eye on your pH. If your pH starts to continually rise to where it is inconvenient, then it would be time to adjust TA.
    Aug 2009
    North Central Texas
    1,358
    Also, it would help to have CH value. TA and CH values can be used to determine a good balance. For example with high CH lowering TA can be a tool to manage high CH if water can't be replaced.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
