Thread: Pool looks good, ready for chlorine and testing
    Jul 2010
    Connecticut
    12
    Just finished a round of shock and now the water looks clear and sparkling. I just did a chlorine test last night and this morning and want some suggestions:
    last night FC 7
    this morning FC 5
    CC zero
    PH 7.6
    CYA 30
    Based on pool calc. and these tests, I think I am losing 2ppm chlorine per day and my target based on CYA 30 should be 4 ppm. So, if I need to add 2 ppm chlorine per day, which in pool calc. comes up to 83 oz of 6% bleach per day. This sounds like alot to me. Am I doing this right ?
    30 ft. round 52" deep above ground pool, about 20,000 gallons
    Starite cartridge filter with 1.5 GPH pump
    22,550
    Re: Pool looks good, ready for chlorine and testing
    For a 30' pool that sounds real good. 83oz per day is not bad at all. I add that much to a 24' pool lately and my CYA is 30.
    Since you lost more than 1.0 of FC overnight, you aren't quite done shocking yet.
    Jul 2010
    Connecticut
    12
    I added about 6 inches of water last night to the pool, so that probably effected my numbers. There is still some green around the edges of the pool, so I am going to brush and shock it to 13 today. Will test again tonight and tomorrow for FC loss.
    Yup, "some green" and "2 ppm drop overnight" means you need to keep on shocking. But "clear and sparkling" means you are almost there.
