Results 1 to 20 of 20
Thread: Views from the bottom of my pool
    jmills's Avatar
    Jul 2007
    Billerica MA
    36
    Thanks to this forum I have the nicest pool water I have ever been in. It is also incredibly clear. Here are a few fun photos showing off my water. These are all real. The only image processing was to shrink them.
    Yes those are real ring bubbles. I just love blowing them. I had to keep quite still and hold my breath for a while to let the surface calm down to get these shots.
    JLM
    12' x 20' Intex Oval Frame Pool, AG
    Waterway 1 hp TWM Cartridge Filter
    4' x 20' solar panel
    41' water depth
    4393 Gallons according to the box.
    Aug 2009
    Central NJ
    47
    Re: Views from the bottom of my pool
    Those were interesting. I keep thinking I should find an underwater camera.
    And, what's funny to me is that I discovered by accident yesterday that you could blow ring bubbles.
    Andy
    11K gal 15x30 AG; 1.5 Hp Hayward pump + XStream 150 sq ft cartridge filter; AquaCal SQ110 heat pump; solar cover; Pool Rover Jr cleaner
    jmills's Avatar
    Jul 2007
    Billerica MA
    36
    These were taken with a Fujifilm FINEPIX Z33 WP. This is a pretty good compact camera for a fairly low price.
    41' water depth
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Those pics were great! Isn't it a great feeling to have the best looking water on the block . So tell me, how DO you blow ring bubbles? I know it is something at which I will want to try my hand or shall I say...lips
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Feb 2009
    West Virginia
    216
    Those are pretty neat photos!
    WV Girl
    Custom "L" shape IG gunite pool, 36K gal., main drain, 2 skimmers, 3 returns, hayward heat pump, hayward 1.5hp pump with booster pump, ozonator, 4 cartridge filter.
    one dear hubby, two waterlogged kids, and lots of good times!
    30,401
    The pics are stunning. Nice work on your water quality.
    Now, the important part.....PLEASE tell us how to blow ring bubbles....inquiring minds want to know!
    Aug 2009
    Central NJ
    47
    I don't know about jmills, but I ended up with ring bubbles by being at the bottom of the pool, looking up, then simply letting out a little air. I didn't blow the air out; just sort of quickly opened & closed my mouth to let some air out. My daughters & I had been watching each other blow air bubbles & I wanted to see the bubbles from below... and sometimes, rings happen.
    Edit: I particularly like the 2nd photo, loooking up at the trees, because it practically looks like there is no water.
    Andy
    Southern Indiana
    84
    great job, jmills - the pool and the photos - showed the bubble photos to my family and they didn't believe they were real - such cynics!
    25 K gal, vinyl, IG, next to forest,liquid chlorine and tab chlorinator backup,55gpm sand filter,1.5hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I don't have a waterproof camera, so I'm SOL there. But I may just try the ring bubbles. I can blow smoke rings, it ought to be similar....
    Water looks great. You need to invite some folks over, preferably someone with a milky pool. Their kids are likely to blurt out the obvious
    My wife's best friend brings her kids over to swim, even though their apartment complex has a pool. The kids like the clean pool better, and mom actually will get in here.
    jmills's Avatar
    Jul 2007
    Billerica MA
    36
    To blow ring bubble you do have to have your moth pointing straight up. I use a scuba mask to keep the water out of my nose and see what I am doing. Next pucker your lips like for a kiss. Then puff out a short blast of air. With practice you can get different sizes depending on how much air you expel. Start small, its more reliable.
    JLM
    41' water depth
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I gotta admit, I spend about 2 hours trying to blow ring bubbles yesterday evening. I got it! Thanks jmills for the little lesson. My life is now complete!!
    Apr 2010
    Buckeye, AZ 85326
    619
    If anybody needs me I'll be at the botom of my pool trying to blow ring bubbles!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    This reminds me of a time long pass where we use to sit on the bottom of a 18ft deep pool and blow bubbles and sometimes bubble rings. They lasted, what seemed, forever as they made their way to the top.
    I think if I went down 18 feet these days, my head would implode.
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Thank you for the inservice on how to blow ring bubbles or is it bubble rings I'll be glad to pay you in lessons on how to speak Pig Latin
    Kias; laughed heartily at an imploding head. You crack me up.
    Re: Re: Views from the bottom of my pool
    Quote Originally Posted by Dora
    I wonder what the shock level for that would be....
    Rob B
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Quote Originally Posted by Kias
    Sent from my Droid using Tapatalk
    I guess it all depends on whether or not you have s@%#! for brains!
    (Sorry, I couldn't resist!)
    Love TFP? Become a
    TFP Supporter!
    OMG!! I just spewed my drink all over my phone LMAO!!
    Rob B
    My head is blowing up from reading this thread.
    25x25x16 L shaped concrete, 4' to 6', 21,000 gal, PLP4 - Pro Logic System Control & Aqua Logic Salt Chlorine Cell, Hayward TriStar 1 HP, 24" Sand Filter, SunHeater Solar Heating System, ColorLogic Light, Jandy deck jets.
    Jan 2010
    Central Valley, CA
    233
    Was already heading to the pool - now I have a purpose other than forgetting work!
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
  20. Back To Top    #20
    Never have tried the bubbles, but I do have an underwater camera...
    http://www.google.com/products/catalog? ... 8wIwATgA#p
    fuji xp10 for ~$150 shipped. Pretty nice camera overall...especially for the price. Took me a long time to research one and found this by accident. Glad I did.
    Well now I have a mission for tonight...learn to blow bubbles!!
    25k gal vinyl AquaRite T-15
