Thread: valve filter problem/question
    Jul 2010
    col. Ohio
    15
    the control on the top of the valve( the one to switch from filter to wast to backwash etc.) is leaking, right from the black handle where is has the little arrow pointing to each position. how can this be fix if at all. or do i need to replace it
    its coming out more no then it was last week.
    10,000 gal. above grnd.
    300 # sand filter
    solar cover(do not use often)
    22,553
    Re: valve filter problem/question
    You can take the top off those valves and replace the o-rings and gaskets in them. You should also replace the spider gasket while you have it apart. Be sure to lube them when you're putting it back together.
    Jul 2010
    col. Ohio
    15
    are these parts readily avval at the pool supply? what type of lub? vaseline?
    300 # sand filter
    22,553
    Yes, the parts are usually available at your local pool store. Do Not use vaseline!! It's a petroleum based product and will attack the rubber.
    Use silicon pool lube. Your pool store will have that too.
