Thread: Use of Marine Paint on pool steps
    Interlux Brightside polyurethane marine paint was used by a contractor to paint my pool steps this off season, and now it is peeling. I am planning to partially drain and have it re-painted after this season.
    Safety data that I can find seems to relate to the paints application. Does anyone know anything about the safety of these paint peelings in my pool? I have two kids, age 3 and 5. Should I take care of this now?
    Thanks
    48,000 gal 'L', vinyl, Triton sand filter, 1 HP Hayward Superpump, 1/2 HP Polaris pump, CircuPool RJ-60 SWG
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    Re: Use of Marine Paint on pool steps
    I own a marine supply store and sell the Brightside Polyurethane. It really shouldn't be used on fiberglass that is always submerged in water (like pool steps). I know that sounds weird since it is used on boats but it's meant for boat sides and inside that isn't always "in" the water. When you are ready to paint them again, use Interlux Perfection instead. It will hold up much better.
    As far as the safety information, did you try their website: www.yachtpaint.com or their technical service #1-800-468-7589
    14x30 Viking "Santa Barbara" Fiberglass Pool 12,500 gallon
    IntelliFlo Variable Speed Programmable Pump
    Salt Water Generator with AquaRite Electronic Chlorinator
    Pentair Clean and Clear Cartridge Filter
    Thank you lynns.
    I'll give them a call re the toxicity of the flakes, and I'll give this to the pool guy who used the paint on my steps.
    Do you think the paints made for pools should be used vice marine paints?
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    Honestly, I'm not familiar with pool paint. Assuming the steps are fiberglass, I don't see a problem using marine paint. You just need to choose the right one. Perfection is a 2-part paint (like epoxy). This is the type of paint you want to use.
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    Curious if you got any info from Interlux?
