Thread: Stain on Bottom of pool liner
    This stain is forming on the bottom of my pool liner, its not any type of growth, I cant scrub it off, water has always been right on and clear. Help
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: Stain on Bottom of pool liner
    Color?
    if you bring your chlorine level up and hold it up for a few days does it fade?
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    It could be a heavy metal stain. Theres products that can be purchased that can remove them. I use one called stain free, It has worked great in the past.
    First is the stains dark or black in color or get worse when you add chlorine/shock your pool? Whats your PH? You'll probably need to raise your ph before adding.
    WHat is your means of testing?
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    22,548
    Try a couple of things.
    1. hold a trichlor puck on it for a few minutes and see if it changes.[/*:m:1b4t36zj]
    2. If that doesn't work, hold a vitamin C tablet on it for a few minutes.[/*:m:1b4t36zj]
    Let us know if either of those change it any.
