Thread: pump leaks at times
    pump leaks at times
    i have an intex pool with swg and aquaquick sand filter i cant remme the size of the pump 1/4th or 1/3rd HP its the larger one. anyhow i never had any problems that weren't rectified buy some reoutine maintenance. but lately i've been coming home to my pump running ( its on a timer) and its got water coming out from around the ring i unplug it and re plug it and all is well. i add some water and then salt ( usually) and the next day or so bang its doing it all over again. i took it apart and put a thin film of petrolium jelly on the gasket and replaced everything and it seamed to hold and seal up pretty good. im just leaving the pump on 24hrs a day. anyone have any idea why its doing that?
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: pump leaks at times
    The 0-ring could be shifting and allowing water to pass by it. Keeping the 0-ring lubed is a good idea.
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
