Thread: sealing stamped deck
    Hi,
    I have a stamped deck that I want to seal.
    2-3 yrs ago I sealed the deck with: DECK-O-GRIPĀ® W/B
    Water-Based, Acrylic, Slip-Resistant Concrete Deck Treatment
    I did not like the non-glossy. I want to use a high-gloss sealer and my question is if I have to remove the deck-o-grip I put 2-3 yrs ago? If so, with what? Can I just power wash the thin layer that is left?
    Thanks in advance,
    ~jv
    ps what is a good high gloss sealer? I'm also thinking of using EZ-Tique Water-Based Antiquing Wash. http://www.prolinestamps.com/colors_and ... aspx?id=17
    any advise would be greatly appreciated.
    25k gallon kidney shaped pool
    1 hp pump
    cartridge filter (4 cartridges)
    jandy deck jets
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: sealing stamped deck
    anyone????????
    1 hp pump
    jandy deck jets
