Results 1 to 9 of 9
Thread: DE Filter Material
    Nokesville, VA
    18
    DE Filter Material
    I remember reading somewhere that there is a product that can be used in DE filters in place of DE ... but I didn't save the link!
    Has anyone used anything other than DE in their DE filters?
    42,525 gallon IG gunite pool with DE filter and spill-over hot tub.
    NJ
    291
    DE is so cheap, why are you interested in a replacement?
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    There is something called zeolite or zeobrite. I think it might filter better than DE, but not sure I remember correctly.
    You can also add a little of it to cartridge filters to really polish your water, something you cannot do with DE. (you can add either DE or the zeo to a sand filter, however.)
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    I believe the DE alternative is called Filter Aid and it's made of cellulose fiber. I think the claimed advantage over DE is that it's less hazardous to human health (DE can damage lung tissue if it's breathed in; it's otherwise inert and harmless).
    Zeolite is NOT a DE replacement. It can be used in place of sand in a sand filter.
    Quote Originally Posted by KurtV
    ...Zeolite is NOT a DE replacement. It can be used in place of sand in a sand filter.
    Oops, my bad!
    Guest
    Perlite, a type of vocanite mineral, is the other DE substitute available. Both Perlite and cellulose fiber are more expensive than DE and IMHO, offer no real advantage.
    Nokesville, VA
    18
    I was looking for a possible replacement because of health issues, not cost ...
    Mar 2007
    Coastalish 'down easter'
    4,160
    Lisa, just wear a partical mask when handling the DE in it's dry form
    Luv& Luk
    -Ted
    Guest
    Handling DE powder is probably much less dangerous than handling muriatic acid or even cal hypo, just use common sense and wear a mask.
