Results 1 to 16 of 16
Thread: TA around 300??
    Near Nashville TN
    50
    TA around 300??
    New pool- Autopilot SWG- no salt added yet, just bleach- Using a TF100 test kit. No CYA added yet (getting the pump working first)
    Chl 2.5
    PH 6.8
    TA 300???
    CYA- 0 of course
    Temp 88
    Could my TA be that high- it's tap water from my house? If so, what do I do to lower from that amount- it is a salt pool with a vinyl liner, so any help would be appreciated
    20x40 In ground Grecian Lazy L- Vinyl
    AutoPilot SWG Dig-220, SC-48
    Hayward Dual speed 1.5 hp pump
    Hayward sand filter
    Blue Diamond Robotic Vacuum
    BBB method BABY!!
    30,421
    Re: TA around 300??
    Hey, Kev,
    Chances are your TA is not that high. The R-0009 reagent in your TF-100 has a tendency, when fairly new, to put out drops that are too small and skew the test result.
    It will go away in a month or so, I'm not sure exactly how long that condition lasts........meanwhile, the work-around is to wipe the dropper tip at least every 2-3 drops as you are introducing the R-0009 into the test cylinder.
    South Central NJ
    3,192
    Re: TA around 300??
    Well or municipal water?
    I would retest.The new bottle tends to have a static cling that can create small drops with this reagent. As Bruce suggested, wiping the tip frequently with a moist cloth will discharge the cling effect and allow normal sized drops and accurate results.
    Scott
    Owner of - PoolGuyNJ LLC
    Re: TA around 300??
    I tested my tap water at 340 TA. It lowered over time with aggressive TA lowering, and the lowered more with normal MA additions to control pH. If your pH is really 6.8 that ought to rise soon. But TA is about the last thing you worry about.
    With pH in range, which it is, then get the CYA and FC in there.
    Near Nashville TN
    50
    Re: TA around 300??
    Quote Originally Posted by PoolGuyNJ
    Scott
    City water,not well
    Hayward sand filter
    BBB method BABY!!
    Near Nashville TN
    50
    Re: TA around 300??
    Quote Originally Posted by anonapersona
    My PH was higher 7.4, the other day- why would that drop to 6.8? You say it should rise soon- that's with me adding baking soda, not naturally rises right?
    Hayward sand filter
    BBB method BABY!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: TA around 300??
    Welcome to TFP...High TA leads to frequent PH rise. I would retest your PH to ensure you did it correctly. Having your PH drop from 7.4 to 6.8 did not happen naturally with TA at 300...did you happen to add anything to the water in between tests?
    You'll want to get the TA addressed if you happen to have high CH as well to prevent calcium scaliing. PH at 6.8 is too low, you should raise it to 7.6 by aerating, then add acid to lower PH to 7.0, keep aerating ...let it rise to 7.6 again...repeat. Acid lowers TA and PH and aeration raises PH without affecting TA.
    The process of lowering your TA is described HERE
    Read up on all the pool school artcles
    Near Nashville TN
    50
    Re: TA around 300??
    Well I tried wiping off the tip per instructions when checking my TA with the TF100 kit- Here's my numbers
    Chl 2.5
    PH 7.8 - I measured 6.8 last time- i think the test kit I used was old
    TA 240??? I thought it was 300- still very high
    CYA- 0 of course
    Temp 88
    So, should I start with the muratic acid?
    Hayward sand filter
    BBB method BABY!!
    30,421
    Re: TA around 300??
    How does your water look?
    How new is the pool?
    How are you chlorinating now?
    When are you planning to turn on the SWG?
    I think I would certainly suggest dropping pH down to 7.2 with muriatic and then probably get enough CYA in the pool to get to 60ppm as first steps. Let us know those questions.
    Near Nashville TN
    50
    Re: TA around 300??
    How does your water look? Water looks fine-clear
    How new is the pool? Filled in with water this week
    How are you chlorinating now? Adding 2 gal of bleach a night (2 jugs-small jug)
    When are you planning to turn on the SWG? Added 680 pounds of salt yesterday- will activate the autopilot real soon- waiting for the minimum requirement-forget what it is right now
    Hayward sand filter
    BBB method BABY!!
    30,421
    Re: TA around 300??
    That gives us a good picture of where you are.
    Ok, so....
    I'd still do that.
    Next, I would get the SWG up and running and tuned in. If that takes a while, drop back to no more than 1 small jug of clorox each evening to compensate for the newly introduced CYA.
    So,
    1. drop pH to 7.2
    2. Calculate enough CYA to get to 60ppm and add
    3. Get Swg running and FC stable in pool.
    Once those are done, we can help bring the TA down but I suggest doing it after completing the above.
    Is this a vinyl pool? Did you perform the CH test?
    Near Nashville TN
    50
    Re: TA around 300??
    Ok, so....
    I'd still do that.
    So,
    1. drop pH to 7.2
    No- I thought CH wasn't for vinyl pools-should I?
    Hayward sand filter
    BBB method BABY!!
    22,550
    Re: TA around 300??
    CH isn't an issue unless it's high. I recommend checking it to be sure it isn't high.
    Re: TA around 300??
    There is no need to add CH to a vinyl pool, but high CH level can still cause problems, especially since your TA is so high.
    Near Nashville TN
    50
    Re: TA around 300??
    FYI CH was 0- put the drops in and stayed clear, didn't turn red.
    Hayward sand filter
    BBB method BABY!!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: TA around 300??
    Sounds like something went wrong; if your CH = 0 the solution would immediately turn blue. Did you forget the indicator dye?
