Results 1 to 13 of 13
Thread: A change to the slideshow...
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I've finally gotten the slideshow randomized. It will no longer show the same pictures in the same order. Now they will be shuffled each time you visit so you can see an even better assortment of our member's beautiful pools!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    ktdave's Avatar
    Katy, TX
    888
    Great Idea Sean!
    No offense to Buggs and Maxsrents (I love both of your pools), but they were the only pools I hardly ever saw on it. I usually am on the home page only a short while, then jump into the forum.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    NJ
    91
    No offense taken! I too think its a great idea.
    Carolyn
    22X44 freeform gunite with DE filter (44,500 gallons), 4 deck jets
    mbar's Avatar
    Ashland PA
    257
    It would be nice if the name was with the pool too
    16x33 fiberglass pool sand filter
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by mbar
    ditto: Great Idea! ......Sean?
    You're done SLAMing when:
    SeanB's Avatar
    Mar 2007
    2,622
    We'll see. It may be awhile on that one.
    I may also work on adding a members picture gallery.
    TFP Founder
    Jul 2007
    Suwanee, GA
    528
    How about allowing a picture of the user's pool in their public profile. I often associate some users by what I remember of their pool. ie. ktdave, waterbear, and skinnydipper to name a few. I see their names, I picture their pools. I'd be nice that have that for everyone.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    I second the idea of labeling the slide show, when you get a spare minute or two!!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    SeanB's Avatar
    Mar 2007
    2,622
    Quote Originally Posted by crabboy
    Any member can upload a picture of their pool to their avatar as waterbear has done. A gallery would also adress this issue. With the new version of the forum software just around the corner, I'm hesitant to make too many significant changes as they would have to be redone whenver we make the upgrade.
    TFP Founder
    SeanB's Avatar
    Mar 2007
    2,622
    Quote Originally Posted by The Mermaid Queen
    Unfortunatley, it's not that simple. Initially, I just used the filename for the photos of whatever the members used. More recenlty I have started naming them using username's but it is still probably only about 50/50. Basically, in order to incorporate the names, I'd have to remove every picture, rename and re-load them and then figure out a way to have the filename displayed in the slideshow.
    It may be a lot more feasible to add a gallery where members could have their own photo albums.
    TFP Founder
    Butterfly's Avatar
    South Carolina
    10,045
    Sean, you are so nice and you have all of us spoiled rotten!
    You know how kids like to push the envelope, maybe you should treat us more like (your) kids and tell us "NO" every now and then!
    Can I be barred for comments like that? oh no, .....
    Joyce
    Arizona
    924
    Super! I also agree, Sean is good to us.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Joyce, If I have not been banned yet, you will NEVER be!!
