Results 1 to 8 of 8
Thread: Fairly new pool owner looking for the easy way
    Jul 2010
    Houston,TX
    38
    New home with pool for about 6 weeks. 17000 gal with spa, ozonator with puck feeder. After about a month I thought I had it figured out, the pool was crystal clear, FC was running 2-3 and Boom I got green walls. I had been lurking about on this site but hadn't bought in yet. So now I check the cya and its over 100. I do a partial drain and get it down to 40 and decide to shock to 24 because I also see something funky in the deep end that looks yellow/brown and green about the size of silver dollar. I'm using 10% bleach now and the pool calculator but it is really using alot of chlorine for the first 18 hours will this continue? Also with cya 40 and FC at 24 is it safe to swim?
    17,000 gal in ground with spa, wet edge surface, Paramount PCC 2000 in-floor cleaner,Pentair Clean and Clear Plus 520 Cartridge filter, 3 hp Pentair Intelliflo VS SVRS pump , waterfall with 1 1/2 hp booster, Del ozone Eclipse1 ozonator, puck feeder. Borates added 8/2/2010
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Fairly new pool owner looking for the easy way
    Your shock FC should be 16 at a CYA of 40 thats per Pool School, sounds like you dosed it pretty good. You can swim at shock levels but I think I would let the chlorine get rid of the organics then continue swimming. Dont forget to brush.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Jul 2010
    Houston,TX
    38
    Well I used the pool calculator and for mustard algae it said to shock to 24. I made an asumption that it was MA. Was that incorrect?
    Jun 2010
    Glendale, CA
    513
    not a big deal really. more is better than less.
    You're chlorine is being used up by all the stuff (Algae, etc) in your pool. Once it's gone your usage will level off to something like 1 to 3 ppm per day.
    Your pool may get pretty cloudy next. Don't despair. That's all the dead algae waiting to get burned up or filtered out.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Aug 2009
    North Central Texas
    1,358
    Does you pool get a lot of sun? I'm just south of Dallas and my pool gets a good deal of our Texas sizzling sun. My CYA is now between 40-50 but it seems to me that chlorine additions are much more predictable if I keep it 50-60. I purchased 4 lbs yesterday and will start adding, via stocking, in front of return tonight. I lose water to splashout and backwashing and lowering from the on and off multi inch rains we've been having.
    BTW...... The Super Walmart, close to me, is either slowing down on stock, for fall (which is really stupid as our pool season goes through September, without heaters) or there is a back order. The Pool Sections, two, were missing a lot of products. I like the HTH Stabilizer/Conditioner as it dissolves so fast. I've been checking our local HD all year and they have the HTH S/C on the shelves for the first time since last summer. I don't know if they ever carried it but surely hope they keep selling it. The price is good at $15 for four lbs; same as Walmart.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Jul 2010
    Houston,TX
    38
    Ok this afternoon my FC in 15.5 but I'm shooting for 24. I think one of two possibilities, 1) my pool is larger than I think but I'm using the contract that states how much water my pool will hold. or 2) Something is unsing up the chlorine. The funny thing is the water is clear. It actually looks pretty good. I have brushe the walls and they look better. Why after adding so much liquid chlorine am I not reaching my desired level?
    Shocking is a process, not a one time addition of extra bleach. Just be patient and follow the rules on shocking in Pool School. Keep it at shock level (I don't know if you need mustard algae levels or not) until there is 1 FC or less overnight chlorine loss; and no more than .5 CC; and your water is clear. How are you doing your tests?? If you don't have a TF 100 testkit or other kit that has an FAS-DPD test so you can know FC and CC, you will have trouble maintaining the pool long term. Even for my used, $100 pool, it was a terrific investment for me to get a great test kit -- most of us think it essential to really taking control of a pool.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Pool is per contract, mostly, then add the spa, the water in the waterfall, the water in the pipes, the water in the filter.
    And something is consuming FC. Sunlight, organics, stuff in the filter, skimmer.
