Thread: Dosing acid... and Bleach
    Dallas TX
    186
    I have a SW pool. The SWG is undersized for the pool - at 100% output it does not make enough FC. All else is good - runtime, all other chemistry.
    I'm going to start supplimenting with bleach to get the FC up.
    I've already rigged an acid doser to maintain pH, using drip lines & fiitings, plugged into the suction side of my pump. It pulls 5% (watered down) acid from a 5-gal pail whever the pump is running. Works like a charm!
    I'd like to set up a similar system for bleach. Any objections to mixing the two chemicals using a T-fitting into the pump??
    or would that just make chlorine gas, and blow up everything & kill everyone ?
    I can water down the chemicals to any 'safe' level. I only need maybe a gallon of regular stregth bleach a week.
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Dosing acid... and Bleach
    I would not suggest storing Bleach and acid anywhere near each other. While I'm sure you can build a good dosing device, one malfunction = kaboom
    Just my opinion.
    They need to mix into the pool water separately, never mix acid and bleach together before adding to the pool. If you are using a pump or injector of some kind for both acid and bleach the injection points need to be at least a foot apart.
    Dallas TX
    186
    Excellent, thanks
    I have a good idea what to do now - hehehe, let the fun begin
    Jul 2010
    Pt. Arthur, TX
    174
    Just out of curiosity, what is your CYA ppm, and your FC ppm?
    Custom Cloud shaped 19'x35' - Raised Spa 6' diameter
    Rainbow 320 Inline Chlorinator - Paramount Clear O3 Ozone Generator
    Hayward C4025 Cartridge Filter (Hayward CX880XRE) - Hayward Tristar 2 speed pump
    Hayward H400Fdn Heater, Hayward GVA-24 (valve actuators)
    Dallas TX
    186
    Quote Originally Posted by thunderkyss
    CYA = 100ppm
    FC = 1ppm
    No issues yet but I'm walking a tightrope...
    see this for more info
    post210007.html#p210007
