Results 1 to 7 of 7
Thread: Polaris Hose stuck in nut!
    I had a leak in a section of the Polaris hose from the unit to the back up valve. When I went to remove the hose, the hose broke off in the nut! I an not get it out - now on both ends.
    Do I have to break the nut off and get new ones? Or is there some trick to get the hose remains out of the nut?
    Thanks.
    zzotto21
    Legacy Rectangle AGP, 13' x 25', 11,200 gal
    Hayward Power-Flo Matrix Pump, 1.5 hp
    Hayward XStream Filter, 150 sq.ft.
    Mojave Desert Heating System 8-)
    22,551
    Re: Polaris Hose stuck in nut!
    Welcome to TFP. There was a discussion about those nuts a while back but i can't find it now. It may not be your particular problem but it might be worth a search.
    Maybe if you post a picture of it someone will know what to do.
    Jul 2007
    Suwanee, GA
    528
    Yes, I'd like to see a picture also. I have had problems with the hoses popping off, but I usually cut an inch off the hose, cram it back on and screw on the nut.
    The nut should back off it twisted...
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    A Picture really will not show anything. The hose is stuck in the not and when I went to pull it out, I ripped it out except for what was left inside the nut! So now I can not get the remains out and I can not take the nut off because the hose remains make it too tight!
    Woe is me.
    zzotto21
    May 2008
    Virginia Beach, VA
    84
    If I'm reading this correctly, it's happened to me, and I felt it was easier just to go buy a new nut for a few $$ then to try to mess with it. I guess you could try an exacto knife or something to cut out the hose, but again, the slices on your hands and frustration probably isn't worth the price (although I am always shocked at the cost of Polaris parts!!).
    Good luck!
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    Exactly what I am thinking. I'll keep everyone posted.
    zzotto21
    Mar 2011
    Sunny Central Florida
    91
    This has happened to me before... I ended up cutting the nut off with a pair of snips and purchasing a new one.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
