Results 1 to 16 of 16
Thread: Brand new pool...and a busted hose
    Jul 2010
    Central Illinois
    50
    I am kinda torked right now....two days of filling the pool and I find that one of my hoses has many holes in it. I am fortunate that I opened up the lines and let the return line fill the filter and tank assembly. It was then that I found water shooting into the air from my skimmer hose. The reason I say that I feel fortunate is...I had not filled the pool up to the skimmer yet...thus no major water loss when I removed the hose.
    Now I have to drive 30 miles tomorrow evening and get the hose. They better give me a new hose..or things will go south real quick. This new pool is not getting off to the best start....when can I expect the fun to begin?
    1) 8500 Gallons (18 foot, 52 inches deep)
    2) Hayward Cartridge Filter
    3) Above Ground Pool
    4) Hayward 2 HP pump
    Guest
    Re: Brand new pool...and a busted hose
    I almost hate to ask, but is it flex pipe
    Jul 2010
    Central Illinois
    50
    Yes it is...I take it that this is a common problem?
    Guest
    Some approve of using it, and some don't. I absolutely do not allow it in anything I am in involved with, for exactly the reason that you are seeing.
    There are no code infractions with using this stuff (toned down version of what I wanted to call it ), so these guys get away with using it. IMHO, the only reason to use this pipe is to go faster. It has absolutely nothing to do with doing a good job or providing a good product for the customer. We've plumbed with rigid PVC for years, and they make 45's and 90's when you have to "bend" the pipe. It may take a little longer, but it is the right way to plumb.
    I really am sorry to hear this. I hate flex pipe; I don't believe it has any place in swimming pool construction!
    Jul 2010
    Central Illinois
    50
    Thanks for the info...I will run it the rest of the season...then I will convert it myself next spring. What you said makes sense...and rigid PVC is not that expensive. The peace of mind for me will be well worth it.
    Thanks again,
    Doc
    Guest
    It will be time and money well spent when you re-do it. I'm glad if I was able to provide some help (us bikers need to stick together ).
    Now, go enjoy your pool
    Jul 2010
    Central Illinois
    50
    simicrintz this is a horrible day....how many times can I tell you how right you are. I came home from work today to find the pool drained below the return line. Guess what the installers chose not to tighten the hose clamps...so now I am topping off again...wasted chemicals and all. I am really thinking getting a swimming pool is not a very good idea. I think I messed up!
    Guest
    Getting the pool was a great decision, especially for all of the good times and memories you will be making
    A pool installer who uses flex pipe and rushes through the installation, only thinking about profit, should be shot (hung, stoned, covered in honey and left on an ant mound, etc.) however
    Hang in there. Once you get the bugs worked out and finish Shmucko's work you'll be glad you did!
    Jul 2010
    Central Illinois
    50
    It is partially my fault...I should have checked them all when I put the skimmer hose on...ughhh....I am so unhappy right now! This pool is not off to a good start.....at all!
    Jun 2010
    NE Ohio
    70
    simicrintz: when my pool was installed about 4 years ago it was plumbed with flex pipes. It still is. Until I read this thread I had never even considered another option.
    I replaced the first set of flex pipes after two years and figured I'd be doing the same at the end of this season...
    Sometimes I realize I'm not as smart as I thought I was
    Since I bring my pump and filter into the basement for the winter do you have a suggestion for an easy PVC disconnect coupling for the pump intake and filter discharge? Also, the pump and filter just rest on a paver base right now, and if they move a bit (they don't, but if they did) the flex pipe would move too. With rigid PVC should the pump/filter base be bolted down...say to a permanent cement base?
    Peter
    21' X 52" above ground
    1 HP Hayward Power Flow Matrix Pump
    Hayward EC40C DE Filter
    Guest
    You should be able to get some threaded unions, Peter. That would allow you to remove and store your components pretty easily.
    Don't worry about the movement. Rigid PVC can withstand quite a bit of shock, and I can't imagine that you would get any more from your pool that anyone else. You should see the movement I get when my solar kicks on and the air clears out of the line Haven't lost a fitting yet though
    Jun 2010
    NE Ohio
    70
    Thanks Bruce. Sounds like a nice little fall project.
    I've spent 4 years fussing over a deck around the pool and never got it done. Maybe I can get the hard wiring, deck and permanent piping done now.
    ...and this is my beautiful wife:...
    and me:...Honey, this year, I promise...
    Peter
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Quote Originally Posted by simicrintz
    i believe he had a/g pool hose, not flex pvc..BIG difference
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Marcm15's Avatar
    Jul 2010
    Orange County, NY
    41
    I was going to ask that same question. I thought there was a big difference between AG Pool hose and Flex Pipe. I just installed my first pool this year and have hoses for my plumbing. My plan is to hard plumb with PVC prior to next season. I do check the connections of my hoses everyday prior to running my filter and inspect the entire length regularly. My wife does say I suffer from OCD and I am starting to think she may be right...
    ~21 ft Round
    ~52 inches high
    ~11,500 Gallons
    ~Hayward EC50 DE Filter and a 1hp pump. Flow Rate of 50 GPM
    Guest
    Quote Originally Posted by Heckpools
    That could be. I have zero experience with AG pools, so I am not sure exactly what is used for these (which is why I asked if it was flex pipe initially ).
    That being said, if I had an AG pool, I would still plumb everything with rigid PVC. Pool hose, flex pipe, whatever they use, can only be so strong. I would imagine it is used for the sole purpose of speed and maybe keeping costs down; two things I have limited tolerance for!
    Jul 2010
    Central Illinois
    50
    I more than likely do not have flex hose then...it sure looks like it would fit the description. But after two mishaps with the pool hoses in the first two days of operation...I agree with simicrintz...the PVC is the way to go. It will give me the piece of mind that I am looking for!
