Results 1 to 9 of 9
Thread: Should a pump feel hot to the touch?
    Near Nashville TN
    50
    Been a few years since I owned a pool. I forgot if a pump is supposed to feel hot to the touch? It also has a little smell to it, figured becasue it is brand new- runs very quiet, but feels hot?? It is a dual spd 1.5 hp Hayward- wired to 240v with #12 wire on a 20amp breaker
    20x40 In ground Grecian Lazy L- Vinyl
    AutoPilot SWG Dig-220, SC-48
    Hayward Dual speed 1.5 hp pump
    Hayward sand filter
    Blue Diamond Robotic Vacuum
    BBB method BABY!!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Should a pump feel hot to the touch?
    It should feel hot but you shouldn't be able to cook eggs on it. Roughly 130-150 is okay anything near 200 is bad. Check near theback vents of the motor you should feel a good breeze of air. It shouldn't have a smell though,especially a burning smell
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Near Nashville TN
    50
    Thanks- it's not a burning smell. More of a "new" smell- like it's just getting used for the first time- it's not an electrical burning smell- hard to 'splain
    Hayward sand filter
    BBB method BABY!!
    Apr 2010
    Buckeye, AZ 85326
    619
    I just got a new pump too. It has the new pump smell as well.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    22,549
    The rule of thumb is, that if you can force yourself to hold your hand on it for 8 seconds it's less than 150ºF. I'm not advocating trying this I have used it a lot in the past.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    X-PertPool's Avatar
    Exeter, PA
    1,385
    it definitely should not smell like burning varnish
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Near Nashville TN
    50
    Well I have rewired the pump with #10 wire, instead of #12 to see if that was causing the pump to turn off as it pulls amps- same thing, low speed runs all night/day, high speed runs for about 20 min then shuts off. Pump gets very hot, which the tech guy at Hayward said it would. I can't hold my hand on it for more than 2 seconds. Low spped, not hot at all. I am going to try to get the temp off of it next. This sucks, it's brand spankin new.
    Hayward sand filter
    BBB method BABY!!
    Jun 2010
    Toms River, NJ
    80
    Three stupid questions: Are you getting the proper voltage at the receptacle? Was the cord wired correctly to the new pump? Are all screw type terminals tightened properly?
    18'x24' (10,000 gal) above ground pool, 19" Proline sand filter (45 GPM), Jacuzzi 1.5 HP 2 speed pump
    22,549
    If it's brand new I'd call Hayward and let them deal with it before I fretted too much about it.
