Thread: Where to add chemicals in an AGP
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Probably not a new topic, but I have a hard time using the search feature on this site Anyway...I have an AGP and want to know the correct way of putting chemicals in the water. I have read to "add the chemicals to the deep end of the pool". What if the pool doesn't have a deep end? Then what
    Currently I use the return area for most all of the chemical applications as this, to me, seems the most logical in lieu of a deep end as the water is circulating and distributing the product into the water.
    Please chime in and give me your insight. Thanks.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Barbara C's Avatar
    Jun 2010
    Southern Indiana
    124
    Re: Where to add chemicals in an AGP
    In front of the return is the place to be to add chemicals.
    Don't feel bad, I haven't had much luck using the search feature either!
    24' AG Vinyl
    13,500 gallons
    1hp Hayward pump
    Sand filter
    Jug dumper apprentice
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Check out sonflower's pdf that has pretty good instructions for everything:
    http://pooldrama.tripod.com/POOL_CHEM.pdf
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    But if you add any CYA..........either put it in the skimmer slowly or hang in a sock to dissolve. Don't just dump it in front of a return.
